LA500A MAY 2021 IMPROVEMENTS
JLM111PCB Transformer now PCB mount with direct plug into PCB.
Slow attack mod built-in with leds for slow attack and stereo sidechain link.
LA500 recall sheet here
LA500A Parts List
http://www.jlmaudio.com/LA500A/LA500A%2 ... 20list.txt
BIO500T PCB kit
3. PCB automatically uses the highest power available. +/-16v for 500 and +/-24v for 51X.
BIO500T PCB.
Fit and solder Relay & DIP8 socket. Make sure the POLARIZED socket matches the PCB overlay. Bend 2 legs out to hold the relay in place for soldering. Solder relay in place once POLARITY has been checked.
Caps 01.uF should be marked 104 or 0.1u or 100n. 47pF should be marked 470 or 47p. Fold 47pF caps down flat to PCB before soldering them.
Some PCB batch have had holes a bit to small, if so click link below to see what to do https://www.jlmaudio.com/forum/viewtopic.php?p=4902#p4902
Fit Transformer to PCB
Fit BIO500T PCB to Bracket
LA500SCv3 PCB parts kit
Fit all 8 x BAT85 diodes with their Cathode POLARIZED black stripe matching the white stripe on the MAC PCB overlay
Solder all BAT85 diodes while holding PCB firmly upside down on a flat surface. Make sure none of the center close pads are NOT shorted together.
Cut all diode legs off at top of the solder joint and double-check no solder joints missed soldering or are shorted together.
Fit and solder Electro caps to PCB. The 5 x 100uF caps are POLARIZED so must have their long positive leg fitted to + marked on PCB overlay.
2 x 3.3uF caps are NON polar types so can go in either way around on the PCB.
Fit and solder 4 trim pots as shown 1k = 102 code. Place pot so the trim screw is in corner shown below
Plugin NE5532AP opamp the correct way around as shown below and put the built LA500SCv3 and the 3 switches leftover back in the plastic bag and move on to the LA500POTv5 kit.
LA500POTv5 PCB holds the Threshold & Makeup pots with their pull switches for slow attack and stereo side chain linking as well as the new leds.
LA500POTv5 schematic here
Solder one pin and check the connector is sitting flat against PCB. If not reheat while pressing on the connector.
C20K dual 20k reverse log pot
A200K dual 200k log pot
The 2 LEDs will NOT be fitted until later when the LA500POTv5 PCB is bolted to the bracket and front panel
Note small jumper wire shown from 10 pin header to pcb via pad so not needed on POTv3 to v5 PCBs
The ribbon cable can be plugged in and bent into shape and then we are ready to move on to the final assembly of the LA500A.
Final Assembly of LA500A
SETUP WITH TOGGLE SPACERS
Remove all nuts and washers from toggles. Fit 2 Toggle Spacers.
Fit nuts on each toggle and only do up finger tight.
Place into the Bracket and fit lock washers and nuts
DO NOT USE TOGGLE SPACERS WITH NO REAR NUT AS IT WILL PULL THE TOGGLES APART.
SETUP WITH NO TOGGLE SPACERS
Wind the back nuts fully down onto the 3 switches. Fit the flat washers on next.
Cut the sides of the middle flat washers with side cutters so it does not overlap the other washers.
Fit the 3 shake-proof washers on next.
The threaded section of the 3 toggles should be level with the meter section of the stainless steel bracket.
Fit Meter into the stainless steel bracket from the front.
Fit front panel and fit 2 meter screws hand tight to hold the assembly together.
Fit LA500POTv5 PCB pots into bracket and front panel and do up pot nuts tight to hold the assembly together.
Lock-tight can be useful in an always traveling lunchbox to stop them from shaking loose.
Hold down LA500SCv5 PCB flat against the meter so it is sitting parallel to the front panel and solder one leg of the top and bottom switches to hold in place.
Plugin ribbon cable from LA500POTv5 PCB and push any extra length back in between the 2 PCBs
Fit short ribbon cable between LA500SCv5 and LA500 PCB
Fit LEDs as shown below. The Long LED leg goes to the square solder pad. Do NOT swap the colours as they will not be the correct brightness.
Solder LED legs to PCB.
Make sure the pots are turned fully counterclockwise and fit knobs so they line up with the MIN dial line.
Compressor setup procedure
4. Adjust meter 0VU trim pot for the desired level for 0VU on the meter.
5. Switch Meter switch to GR and adjust Zero GR trim pot for 0VU on the meter.
6. Turn up Threshold pot until you have 5dB of compression on the meter.
7. Switch Meter switch between GR and VU and adjust the Balance trim pot until the same reading is seen in both GR and VU.
8. You're ready to rock.
2. With 1k tone of the same level into both LA500 comps set 0VU on meter switched to VU and turn up Threshold pot to get -5dB on the meter and switch to GR to check you have -5dB showing on both meters.
NOTE: If comps are very different when linked due to be ordered at different times or batches it is best to swap U1 from one comp with U2 of the other and realign before resorting to stereo match mode. If comps were bought together we will have labeled the opto bags with a U1 and U2 which are already matched pairs
1. Setup both comp with 1k tone and set 0VU on meter switched to VU and turn up Threshold pot to get -5dB on the meter.
4. Switch both comps to GR and adjust modified comp new GR pot until both comps show the same GR meter readings.
To check match
1. With 1k tone of the same level into both LA500 comps set 0VU on meter switched to VU and turn up Threshold pot to get -5dB on the meter and switch to GR to check you have -5dB showing on both meters.
Comp permanently stuck in hard bypass. Then check the meter led lights when switching to GR or VU? If you have an open circuit led in the meter the bypass relay will never operate to lift the hard bypass so you will never hear the comp.
All other pins of NE5532A on BIO500/LA500 main pcb should be close to 0v. Place black lead from your meter on 0v for all voltage measurements.
Test BIO500/LA500 main pcb by itself by unplugging BIO500/LA500 main pcb ribbon cable from LA500SC pcb and fitting two cut-off component leg loops as shown below.
You can plug the relay green wire loop in and out to switch between bypass and BIO500 audio path to check the audio level is correct.
LA500A Parts List
BIO500T PCB kit
BIO500T PCB.
To check match
Hello, I’ve just (fingers crossed) finished building this. Excellent packaging, directions et al!
One point - the BIO500T pcb has 8 holes around the optos, not matching the 4 shown on pix.
One question, possibly related: into the setup and after zeroing the meter I switched to GR. Meter drops like a stone to Zero. Did I pick the wrong holes for the optos?
I recommend all comps being setup using our 500 extender cable or if you have a standard 5 pin XLR 500 power supply use our 500 tester or Dual Tester.techdef wrote: ↑Tue Jun 29, 2021 9:24 amHello, I’ve just (fingers crossed) finished building this. Excellent packaging, directions et al!
One question. I don’t have a good way to reach these trim pots with it racked up. Can I fire it on the bench with 16v from a supply safely?
As you will need +/-16v and balanced in and out to do the alignment and there is nowhere to solder wires to the 500 module so must have a edge connector. If you have a very short screw driver and no modules to the right in a empty rack you can sometimes do the alignment but it is tricky.
I think you mean the 8 holes in the LA500SC PCB? We still recommend using the holes shown in the build thread as it leaves the opto wires longer and easier to work with. But the 4 new holes are just paralleled with these. So each pair of holes that are close to each other are linked. We use these closer holes for our production LA500A as we make the optos pluggable so it is easier for use to pair modules later on.
Ok, thanks. They looked to be parallel so I wasn’t too concerned.
Guess I missed the memo on the extender…
Made a small edit above- fired it on my bench with 16v supply and am able to zero meter but not getting anything in GR mode.
I am feeding it balanced input from an HP200.
“Get an extender” is a fully ok answer, but thought I’d ask whilst waiting for mail.
OK If you align the VU meter to 1.23vac on the balanced output and then go to GR mode the first time the GR should be pinned off the scale and need turning back a few turns to 0. So check you have 5v across the outside GR trim pot terminals and the wiper is varying the voltage. There is really only the toggle switch between this point so make sure you have soldered all the toggle switch legs to the pcb neatly.techdef wrote: ↑Tue Jun 29, 2021 10:23 amOk, thanks. They looked to be parallel so I wasn’t too concerned.
Well, I’ve screwed something up then. Not getting the 5v.
If I’m reading this right, and I’m probably not, the schematic refers to IC2 for voltage drop, but I can’t see IC2 anywhere?
Is the 5v a divider someplace I can trace back?
FWW I get 2v across S2.
The 5v reg is a To-92 transistor looking 78L05 on the LA500SC pcb beside the 2x 10 pin headers.
Send me some photos to check over pcbs.
Mea culpa- it was indeed a test-setup failure on my end. Installed it in the rack and it works flawlessly.
People, don’t be like me! Order your extender!
Cool great to hear you got it working
First time building one of your kits. I got this one built and it powers on with no smoke or explosions, so far so good, but I noticed two issues immediately that I probably have to solve:
1) the blue LED for stereo linking is always illuminated regardless of the knob being pulled out or not
2) for the meter with no audio input, at VU setting the needle is all the way left, at GR setting it's all the way right.
I'm working my way through the old thread to see if I can find another identical issue but they all seem a bit different. I haven't tested audio through it yet but will later today.
Thanks for any help!
-Lokke
-Lokke
I forgot to mention that the blue LED is also noticeably brighter than the amber one.
Best to send me some photos of the built comp to my email to check over for you. But basically sounds like a solder short and or resistor values in the wrong place for led. The metering is correct for the first power up with no signal and GR not set.
Sent photos to Joe, we determined that I had not trimmed the legs of the LEDs before soldering them in, which was causing a short where the leg was touching the pot. Took it apart today and trimmed the legs and put it back together. It's working as expected!Joe Malone wrote: ↑Fri Jul 02, 2021 11:31 amBest to send me some photos of the built comp to my email to check over for you. But basically sounds like a solder short and or resistor values in the wrong place for led. The metering is correct for the first power up with no signal and GR not set.
As soon as my extender cable is here I will finish the setup and be 100% sure it's correct.
Cool great to hear that fixed the led problemlokke3 wrote: ↑Wed Jul 07, 2021 6:20 amSent photos to Joe, we determined that I had not trimmed the legs of the LEDs before soldering them in, which was causing a short where the leg was touching the pot. Took it apart today and trimmed the legs and put it back together. It's working as expected!Joe Malone wrote: ↑Fri Jul 02, 2021 11:31 amBest to send me some photos of the built comp to my email to check over for you. But basically sounds like a solder short and or resistor values in the wrong place for led. The metering is correct for the first power up with no signal and GR not set.
I just built two of these units, and all seems fine. But, I am not able to get any reaction on the VU needle when turning the "Meter 0 VU" trim pot.
This applies to both units, I also tried to switch to GR and tested the GR pot, but still no reaction. I also tried putting the jumper over to "match" put I get nothing at all.
Threshold and all other functions react as expected and sound is flowing through.
Any tips on this one?
- I am sending 1000hz tone from my DAW, into the unit(s) and I have adjusted the input dB so that the LA output is showing exactly 1,23VAC, the needle is beyond 4dB on the VU.
- All knobs counter clockwise
- Ratio 3:1
- Meter: VU
- HPF: Flat
