New PowerStation Ver 2 PCB & Kits now available. Also step by step building info for PowerStation and AC/DC kits now on the web site here
http://www.jlmaudio.com/JLM%20Power%20Supply.htm
PowerStation Ver 2 PCB & Kits Now Available
Re: PowerStation Ver 2 PCB & Kits Now Available
You mention on the website that 2 AMPs is available by adding an additional 4 Diodes. Are these marked on the circuit board or is it something that has to be rigged up externally? Is this 2 Amps split among all 4 rails or for each set of 2? On mine I just put 1N4007 everywhere they were called for on the board. Thanks.
CC
CC
I asked Joe the same question and copied below is his reply.
"In the centre of the AC/DC with the regs away from you. If you
double the 4 diodes to the right (solder a second diode across the diode
under the PCB) it will make the diodes 2Amp so you can get the max of
1.5amps out of the regs but you will need a large heatsink on all regs to
get to 1.5amp.
[If]...you have a powerstation ver 3... all you need to
do is leave off the D1 to D4 and fit a 4A to 6A bridge rectifier so all regs
can get to 1.5amp."
Hope this helps.
get to 1.5amp.
can get to 1.5amp."
Hope this helps.
What's the easiest way to turn the 48volt rail into a lower voltage rail for signal/relay/LED stuff? Say something like 5-15volt?
CC
CC
To disable the Doubler/Tripler on normal 48v rail replace C1 & C2 with wire links and strap D to centre pad and adjust to the voltage you need.conleycd wrote:Hey Joe,
CC
