BA & BAD PCB is designed for easy mounting by it 3 front edge toggle switches like the GO between and GO between plus kits share and are powered direct from one 48v rail supplied usually by our external 48v built MEPS Green SMPS which can run on any mains voltage in the world with out switching. This 48v supplies phantom power and +/-24v for the opamps to run on so makes building may types of transformer input single and dual opamp types of mic pre much easier to build.
What to run the most BA BAD BAN mic pres on the smallest MEPS SMPS power supply please read the Notes and Errata further down this page[/size]
NEW BLACK BA Ver2 PCB
Complete circuit of JLM Baby Animal Ver2 Black PCB here
Note: Build same as old BA PCB except Zpot now has its own 2 pin connector connector and series resistor for Zpot is fitted to Rload on black pcb.
If fixed Z then wire link over 2 pin connector solder pads.
BA PCB
Complete circuit of JLM Baby Animal PCB here
Circuit for Baby Animal Mic Pre with JLM14 & OPA2604 here
Circuit for Baby Animal Mic Pre with JLM14 & JLM99v or Hybrid here
BAD PCB
Complete circuit of JLM Baby Animal Dual PCB here
BAN PCB
See BAN build thread here
The BA & BAD PCB are easy to assemble with all parts with there value marked on the PCB needing to be fitted. Parts marked with * or # and zener diodes are only needed if running on higher than 48v or running opamps that need less then the +/-24v to run on. Parts with a name like Rload, CLoad, Rzobel, CZobel, RPad, RGain need to be selected to match the input transformer and opamp used. Their values for projects like the Dual99v can be found on the overlay sheet for the project.
Original 48 page BA thread on GroupDIY
https://groupdiy.com/index.php?topic=15245.0
Condensed version of The Lab Thread on JLM forum
http://www.jlmaudio.com/forum/viewtopic.php?f=2&t=11
BA, BA2, BA4 Overlay wiring PDF Large PDF copy here
Dual99v, BAD Overlay wiring PDF Larger PDF copy here
BA BAD BAN voltage settings
BA Settings (Ratios higher than 1:6.45 below not recommended unless using 50ohm microphones)
Building API 512, API 312 type mic pre on BA PCB
If using JLM25HV or JLM25HV FET NO BD681 is needed & 33v - 39v zener as they can run direct on the +/-24v of the BA PCB.
Cinemag CM-75101APC on BA PCB
Notes & Errata
DO NOT DO THIS SOFT START MOD TO ANY NEW BUILDS. If building 3 or more BA kits use our 48v 40W SMPS instead as it can run 8 BA BAD or BAN easy
BA MEPS SMPS Soft start mod (DO NOT DO THIS SOFT START MOD TO ANY NEW BUILDS. If building 3 or more BA kits use our 48v 40W SMPS instead as it can run 8 BA easy)
BAD MEPS SMPS Soft start mod (DO NOT DO THIS SOFT START MOD TO ANY NEW BUILDS. If building 3 or more BAD kits use our 48v 40W SMPS instead as it can run 8 BAD easy)
BAN MEPS SMPS Soft start mod (DO NOT DO THIS SOFT START MOD TO ANY NEW BUILDS. If building 3 or more BAN kits use our 48v 40W SMPS instead as it can run 8 BAN easy)
Some helpful photo's (If there is some detail you need a photo off let me know and I will add it here)
BAD PCB fully assembled except for 2 x 270R for RGain, input transformer and opamps Larger photo here
Notes & Errata#BD681 jumper is wrong in the photo below. Should be E-C. Also Dual99v does not use a Cload cap any more. So leave blank.
BAD PCB fully assembled as Dual99v (Note 2 links needed between centre pin and E on each BD681 position and 1mm gap under transformer)
Sit toggle hard against the PCB and solder one front support leg on each toggle to hold in place.
Check toggles level and square to each other and solder all legs and support pins
Dis-guard flat washer and fit the rear nut (should be a few mm gapped from the end of the thread) and washer to all three toggles
Nuts should just screw on an tighten with minimum thread sticking out if the rear nut is set correctly
Nuts and washer order for Power switch
Same again space the rear nut up so the minimum of thread sticks out past front nut.
DC connector and Fuse wiring
All Pot wiring for BAD Dual99v PCB
Gain pot wiring (Photo shows BAD/Dual99v dual pot)
Note BA is the same but only a single pot
Output Pot wiring
Z pot wiring
OEP/VTX = 10k in series with 100k log pot. (As shown in photo below for Dual99v)
JLM14 = 2k2 in series with 50k log pot (2k2 resistor solders to both pins on the left and red wire solders to all 4 pins on the right)
Output transformer to IOXLR PCB (Note link wire between -2 and +3 is hidden in this photo)
Full Dual99v internal wiring Larger photo here
Errata[/color][/b][/u]#BD681 jumper is wrong in the photo below. Should be E-C. Also Dual99v does not use a Cload cap any more. So leave blank.
[img]http
BA PCB
BAD PCB
BAN PCB
Notes & Errata
Output Pot wiring
Z pot wiring
[img]http
Is there a simple overlay showing the values for fitting the OPA and JLM 14? I'm excited to get to building this when it arrives but I still get dizzy when following a schematic. I've only built a couple very simple projects previous to this ( a treble booster and a mic attenuator).
thanks for all the help you provide,
Aric
Aric
Added the two yellow tables in the first post.tenchijin2 wrote:Hi Joe,
Aric
Hi, I wonder if anyone is having the same problem as me?
I built a Ba4 kit using all jlm parts (no o/p trans), and I am getting hissy noise on most settings of the gain pot.
The hiss goes up in proportion to the gain, up to a point, then , at a certain spot the hiss jumps right up, out of proportion to the gain. If I then turn up the gain one more click, the hiss disappears completely whilst the gain keeps going up right to the end stop. All 4 channels behave the same way, the noisy point is around 3.30 o'clock, then clean, noise free gain from there to max gain.
There were several other spots in the gain range that had hiss noise popping up, out of proportion to gain, but I flushed out all the pots with Clean and Lube (heavy handed I know) and that has reduced the problem to the extent described above.
Could anyone please shed some light on this? I am thinking it must be the pots, sometimes I get odd oscillation type noises when in between clicks on the gain pot.
I love these pre-amps, but I'm not sure I am getting all they are capable of, especially with regard to noise.
Cheers,
Paul Maybury.
Paul Maybury
Cheers,
Paul Maybury.
Paul Maybury
Paul
This should not be happening, its certainly not normal BA operation. Can you post some pics of your gain pot wiring and also the top and bottom of your BA build?
Thanks for the reply.
I went back through some emails from Joe, and in one he mentioned snipping out the 2x47pf ceramic caps under the op amp.
I did this today and the noise is gone! However, I'm now getting a thump when applying phantom power, and there is dc showing on the gain pot, about 50mV with phantom on and around 10mV
with phantom off. Also getting a little bit of PSU hash on the channel closest to the power switch. It's not much, only discernable with the gain cranked and no input.
I meant to take some photo's of the innerds, but my 4yo dropped the camera again!
Cheers,
Paul Maybury
Cheers,
Paul Maybury
I would need to see photo's to see what is wrong but check the below list first. It will not be the pots at fault.Paul Maybury wrote:Hi, I wonder if anyone is having the same problem as me?
Cheers,
Paul Maybury.
Paul Maybury
1.Have you got pin 4 to pin 7 wire jumper fitted to the DIP8 socket so quasi balanced out works properly?
2.Rload = 10k Cload = 220pF RGain = 68R?
3.Have you got the output of the BA4 going into a +18dBM to +22dBM pro level balanced input A/D so the noise floor is sitting at the correct level?
4. All wiring short and tightly twisted?
You will always have a small amount of swish noise when moving the gain pot as it is a old school single rail design but this should be very low once the unit has been on for a couple of minutes.
Hi Joe, thanks for replying. All of the points on your checklist are correct in my build. After taking out the 2 ceramic caps under the op amp, the noise is gone, the only issue now is the thumping noise when switching on phantom power. It's minimal if I have the pad engaged when I switch on phantom, and also some slight psu hash (I think thats what it is) on the channel closest to the power switch. This noise decreases in each channel according to how far they are from the power inlet and switch side of the Ba4.
Cheers,
Paul Maybury.
Cheers,
Paul Maybury.
Phantom power will always thump somewhat when turned on. Do you get 48v at pin 2 and pin 3 of the input XLR when phantom is turned on?Paul Maybury wrote:Hi Joe, thanks for replying. All of the points on your checklist are correct in my build. After taking out the 2 ceramic caps under the op amp, the noise is gone, the only issue now is the thumping noise when switching on phantom power. It's minimal if I have the pad engaged when I switch on phantom, and also some slight psu hash (I think thats what it is) on the channel closest to the power switch. This noise decreases in each channel according to how far they are from the power inlet and switch side of the Ba4.
Cheers,
Paul Maybury.
Is the output of the BA plugged into a balanced input pro level A/D +18 to +22dBM ? As this all sounds like a gain structure problem into a -10dbu line input or mic input.
There is no inductive noise from the power switch so it will not radiate noise into anything. So distance to it will not be relevant unless it is to do with power or ground wiring due to wiring length.
Did you fit variable impedance to channels 3 & 4 or was in variable pads?
Do yo have different input transformers on some of the BA PCB's as I cannot remember.
But without photo's to see or info on how you are testing it is very hard to know.
Hi Joe, thanks again for your help.
If the phantom is always going to thump a bit anyway, there's no problem as such. It's no where near as dramatic as the thump my SoundWorkshop console pres make!
My main converters are Motu 24 i/o, RME Fireface and sometimes some MetricHalo's on loan. All are +4 balanced input. I usually do my testing with a small mixer and a pair of Grado headphone's, which are frighteningly revealing. I plug the Ba outputs into the +4 balanced ins of the mixer.
I am getting 48 volts (+/- 0.5 v) at the input xlr's.
I am using JLM input trans, 99v opamps, no output trans. I haven't installed the variable pads that I purchased with the kit in channels 3 and 4, so there are small holes in the front panel for these. I plan to get the variable impedance controls in these channels instead. The first two channels have di's fitted.
Cheers,
Paul
Cheers,
Paul
I'm just finishing up a couple of BAD cards using the VTX 102 003 input transformer, which can be wired low (6.45) or high (12.9) gain. Given the BAD isn't exactly short on gain (we'd be talking 74.5db vs 81db as the choices!), my instinct is to use the low gain jumper. One reason for wiring high might be for tone - is there any difference in the sound by wiring high? Or is there some other reason to wire for high gain?
I only recommend LOW ratio always with the VTX 102 003 / OEP262A3C. Unless you have some 50ohm mics that will work with the 150ohm input impedance when the HIGH ratio is set.chrisp wrote:I'm just finishing up a couple of BAD cards using the VTX 102 003 input transformer, which can be wired low (6.45) or high (12.9) gain. Given the BAD isn't exactly short on gain (we'd be talking 74.5db vs 81db as the choices!), my instinct is to use the low gain jumper. One reason for wiring high might be for tone - is there any difference in the sound by wiring high? Or is there some other reason to wire for high gain?
What, like my matched pair of Reslo ribbons?
Nah, I'm joking - LOW it is. Thanks for the response.
Is there anyway to incorporate an insert for unbalanced compressor like RNC?
The BA PCB is only one gain stage so there is nowhere for a unbalanced insert. Just plug the output of the BA into the RNC.rpagala wrote:Is there anyway to incorporate an insert for unbalanced compressor like RNC?
With the BAD Dual99v there is two gain stages so there is a unbalanced insert point if you cut the O wire going to the output level pot.
