Variable HPF filter kit
A quick noob question, I just want to confirm the polarity for the 100uF capacitor that goes on the underside of the PCB. There is a small white dot on the PCB, does this indicate the polarity? If so, does the dot indicate positive or negative?
Re: Variable HPF filter kit
We supply a Non Polar 100uF cap so It can go in either way around.brett49 wrote: ↑Sat Dec 07, 2024 9:53 amVariable HPF filter kit
Ha, Sweet. I assumed it was polarised because one lead was longer than the other. Thanks for you quick reply.
