GAIN Mic Pre / Makeup Amp Kit
GAIN Build Thread
GAIN Build Thread
Gain PCB is a gain makeup up amp using a single DOA opamp and output transformer or DIP8 dual opamp for electronic balanced out.
Gain PCB runs on a single +V power rail and makes the opamp run in a vintage 1/2v rail configuration.
Example if running a 2520 opamp on +/-16v = 32vdc total. Set the 10k trimpot for 32v from the BD681 reg at +V opamp socket.
GAIN PCB is a cut-down version of our BA Mic pre PCB leaving off the 48v, pad, phase switches and input transformer
Re: GAIN Mic Pre / Makeup Amp Kit
fragletrollet wrote:
Sun Oct 31, 2021 6:12 am
Hello!
See just started above Build thread with schematic above
Any schematic for this one? Is it the RGain or 33R resistor that's supposed to be 1/2w?
33R which drives the output transformer.
Value of CL and CZ? Are RZobel resistor only needed if using an input transformer?
Yes correct
As this board makes a bipolar supply from a 48V source, can I just solder wires to the opamp power pins as to further use the bipolar supply for other boards?
No not easily as it is setup like a vintage gain amp to run on a single +V. Use our Dingo kit or PCB if you want to run on +/-V
Planning to use as makeup gain for some passive pultec boards. They need a high impedance load (at least 470k) and apprx 20-23 db gain. Is the RLoad where I would place my 470k?
Yes but with that high impedance you have to watch the output offset of the opamp due to the input transistor current. I don't know of any passive eq that needs that high impedance as they were all made low impedance to keep noise low.
Just install a trimmer for RGain to trim for unity? Recommended value, 5-10k?
Either 5k or 10k will fine.
fragletrollet
Post by fragletrollet »
Thanks for the feedback.
I have various passive EQ's from Ian @ customtubeconsoles (Helios & Pultec), which are re-designs based on the named units. 470K input impedance is specified in all the gain makeup amps, although differing in how much gain they need. So you're saying other/the original passive designs use low impedance for the makeup amp input? I'm pretty confident in Ian's design choices in regards to these circuits, so a little surprised :shock:
Is the JLM Gain pcb running on a reference of 24V, for +/- 24V = 0-48V? So it works fine cascading more Gain pcb's but if you want to add a board that uses the conventional +/- 24V (-24v/0v/24V) this can't be done as the reference is shifted between the two?
I want to add a simplified passive eq (say just two bands, high and low shelf) to my new tube compressor build, and was hoping to add a m/s board using THAT chips, all running from a SMPS instead of a toroid. So I guess I'll have to use a bipolar SMPS like this in addition to the 48V SMPS I allready have installed in anticipation of the GAIN pcb's.
So, how do I "watch the output offset" and make sure it works nicely with such a high input impedance?
And, BOTH 33R resistors should be 1/2W then I presume, both being opamp outputs? The marking on the pcb is a little confusing.
Thanks again and all the best,
Magz
Thu Nov 04, 2021 4:22 pm
Pultec EQ are actually fairly low output impedance which usually feeds an audio transformer before the high input impedance of the tube. But since you give me no schematic to go on I cannot advise as I do not know if you are including this transformer or not or which circuit we are actually talking about. But you can make RLoad 470k and see if the output of the opamp you choose to use is sitting at 22v to 26vdc as then it is fine. But most bipolar input opamps draw input current so the higher Rload the most the offset from center on output. If there is a transformer and it is floating secondary into the gain then don't use a blocking cap Cdc and the resistance of 470K will mean nothing as the transformer winding resistance becomes the actual input resistance and little if any offset will happen. Or use a fet input opamp so it has a similar input impedance with no current like a tube.
Yes. If you want to do the same as the gain but with +/-V rails then use our dINgO kit which is the same but runs on +/-V.
I Have run many THatcorp the same way as the GAIN you just have to understand and design for -V to be 0v instead.
See above in this reply
And, Both 33R resistors should be 1/2W then I presume, both being opamp outputs? The marking on the pcb is a little confusing.
The other 33R is only if you use a dual DIP8 opamp so running electronic balanced out so both 33R can be anything as they will not see a low impedance output transformer primary.
It is always easier to email me a rough overall schematic first so I can advice the best way to go about making it work as I can always simply most designs and save money for you.
JOETONE
Post by JOETONE »
Hi - Looking similar application with passive EQ makeup gain.
A little confused--
RGain - fixed resistor setting the max gain from DOA?
GAIN - 10k Rev log applied to control/trim the gain.
Do I need to have a resistor value inserted into "RGain" if I just hook up the the C10K pot to "Gain" and that is my Gain control?
Thanks,,, wanted to figure this out -- components en route.
JOETONE wrote:
Fri Jan 27, 2023 9:30 am
A little confused--
Yes Rgain is in series with the 10k rev log pot or trimpot and just stops the gain pot when it is shorted, putting the opamp into infinite gain which can be bad for it. You can just fit the RGain resistor and short the gain pot terminals together to give the correct set gain for a set makeup passive EQ amp
JOETONE
Post by JOETONE »
Does IC1 need to be fitted at all if using unbalanced out?
Which 33R & 47pF are not needed if unbalanced out?
The ones closer to IN/OUT
or
The ones closer to GAIN/POWER
JOETONE
Post by JOETONE »
JLM Twenty Five Twenty can run on this PCB +/-24, correct?
Just Link C to E?
I assume the 2520 note for the DOA 32v +/-16 rails for this PCB is just for Api-Originals, right?
JOETONE wrote:
Sat Jan 28, 2023 4:34 am
Yes
Just Link C to E?
Yes you can but if you want soft start and extra regulation just fit BD681 and turn trim pot up to full to get about 46v (+/-23v)
For most 2520 and clones. Not for our Twenty 5 Twenty
JOETONE wrote:
Sat Jan 28, 2023 12:42 am
Yes, you need IC1 always either a DIP8 or DOA is needed for the GAIN to work.
JOETONE
Post by JOETONE »
Struggling a bit with this PCB but I know I'm close.
I have the Gain PCB voltage set to DOA @ 22vdc
1k resistor in RGAIN
10k rev log pot: GAIN to wiper, 0v to outer lug
So, with no DOA inserted I read from the DOA PCB pins: +V=22vdc, 1/2=11vdc, Out=10.29vdc?
This correct?
It'll pass audio with the DOA inserted, but not getting any boost in gain/level...
JOETONE wrote:
Mon Mar 13, 2023 2:18 am
This correct?
But yes with 22v you should have roughly half that at the output of the opamp if running ok. With gain pot shorted and 1k R Gaiin you should have a gain of 11. What DOA are you using that needs so low a voltage of +/-11v = 22v?
Can you send me a couple of photos to check over?
JOETONE
Post by JOETONE »
Ok, Should V+ be the total voltage? I set to 22v, should that be 44v to get +/- 22 to the DOA? -- the DOA is your Flick.
JOETONE wrote:
Tue Mar 14, 2023 5:42 am
Yes for the flick if running on a 48v regulated rail just turn the trim pot fully up to get about 46v = +/-23v for Flick.
Did you solve the no gain problem?
JOETONE
Post by JOETONE »
Still not getting Gain, but voltage readings V+, 1/2V, 0V, Out now look correct.
