AUX8 Build thread
AUX8 Build thread
Notes and Errata Ver 1 PCB.
AUX8 BOM Parts list
1 x AUX8 PCB
2 x right angle IDC 16 pin pcb headers
9 x 2way headers
8 x 10k metal film resistors
2 x 820R metal film resistors
8 x dual or dual concentric 9mm 10k log pots
fragletrollet
Re: AUX8 Build thread
Post by fragletrollet »
fragletrollet wrote:
Tue Nov 24, 2020 2:16 am
Thanks for posting Magnus :D 8)
znjamznjam
Post by znjamznjam »
Hy Can you post fpd i really like you design.
Can you also make more pictures of wiring?
Can you also use direct bus out without summing to one stereo out from summing?
This is great diy but very little info about.
Thanks in advance
regardes
Neno from NL
The AUX8 and SUM8 pcb is a 8 channel mono or 4 channel stereo depending on pots used with active virtual ground summing and 8 channel mono or channel aux master with inverting stage. So basically it can do 8in x 8out matrix. The pcbs are unbalanced in and out but if you use our palpigrade and tradigrade kits they plug in and give balanced in and out on DB25 Tascam standard.
znjamznjam
Hy
Thanks for info. If I order pcb's do I get what info (schematic for wiring etc)
regardes
neno
AUX8 & SUM8 Schematics now on each thread
A great example of the type of mixer that can be made with AUX8 & SUM8 at the link below
https://www.jlmaudio.com/forum/viewtopic.php?f=2&t=342
fragletrollet
Finished panel design and got my panel cnc'ed and delivered. Still have some work to do before the unit is all finished, but I can verify that my panel design fits with my selected components and pcb's.
fragletrollet
More pictures.
fragletrollet
Holes in the last slot are in my design supposed to fit a label strip for labeling the destination of each aux bus. The strip will need cutting and drilling, I've yet to do this. Holes can also be used for signal/overload LED's, but the holes are a little too small for 3mm led's (initially designed for m3 screws). I'll probably use the middle hole for an overload led fitted behind the strip and the ones on either side for strip mounting.
fragletrollet
Panel design files. Go crazy!
fragletrollet
I'm going for these knobs.
fragletrollet
znjamznjam
Nice, looking good.
