AUX8 Build thread
AUX8 Build thread
Notes and Errata Ver 1 PCB.
AUX8 BOM Parts list
1 x AUX8 PCB
2 x right angle IDC 16 pin pcb headers
9 x 2way headers
8 x 10k metal film resistors
2 x 820R metal film resistors
8 x dual or dual concentric 9mm 10k log pots
AUX8 BOM Parts list
1 x AUX8 PCB
9 x 2way headers
Re: AUX8 Build thread
Thanks for posting Magnusfragletrollet wrote: ↑Tue Nov 24, 2020 2:16 amI was designing an 16x8ch AUX expander for my newly built DIY-Racked DR2402, wanting to use the JLM Palpigrade for the inputs, CAPI 4xInvACA for summing and the JLM Tardigrade for the balancing of the outputs. Trying to minimize wiring, Joe kindly offered to draw up some pcb's that would fit the panel artwork I'd been working on, using the 500-series format for the modules, a choice of mono/stereo channels and concentric or dual (or single) pots and summing network. Personally I'm going to use the SUM8 post CAPI ACA for waveform inversion and as a nice board to host the pots of the outputs.
Hy Can you post fpd i really like you design.
Can you also make more pictures of wiring?
Can you also use direct bus out without summing to one stereo out from summing?
This is great diy but very little info about.
Thanks in advance
regardes
Neno from NL
Thanks in advance
regardes
Neno from NL
The AUX8 and SUM8 pcb is a 8 channel mono or 4 channel stereo depending on pots used with active virtual ground summing and 8 channel mono or channel aux master with inverting stage. So basically it can do 8in x 8out matrix. The pcbs are unbalanced in and out but if you use our palpigrade and tradigrade kits they plug in and give balanced in and out on DB25 Tascam standard.
Hy
Thanks for info. If I order pcb's do I get what info (schematic for wiring etc)
regardes
neno
regardes
neno
AUX8 & SUM8 Schematics now on each thread
A great example of the type of mixer that can be made with AUX8 & SUM8 at the link below
https://www.jlmaudio.com/forum/viewtopic.php?f=2&t=342
Finished panel design and got my panel cnc'ed and delivered. Still have some work to do before the unit is all finished, but I can verify that my panel design fits with my selected components and pcb's.
More pictures.
Holes in the last slot are in my design supposed to fit a label strip for labeling the destination of each aux bus. The strip will need cutting and drilling, I've yet to do this. Holes can also be used for signal/overload LED's, but the holes are a little too small for 3mm led's (initially designed for m3 screws). I'll probably use the middle hole for an overload led fitted behind the strip and the ones on either side for strip mounting.
Panel design files. Go crazy!
I'm going for these knobs.
Nice, looking good.
