PM2000 solo mod question
haima
Post by haima »
i was wondering if the solo mod disabled the normal (stock) routing of audio to the cue bus?
i was thinking perhaps you could put a master switch on the relay (and lamp?) power bus and disable the solo in place for tracking situations - still use the solo in the original way.
i.e. when tracking, if the PM2000 doing both control room monitoring AND headphone mixes, it would be nice to be able to solo a track and check the signal on headphones, without effecting (muting) other tracks for the musicians mixes.... if you get my drift.
and then when mixing, flick to the solo in place mode...
not having schematics i'm not sure what else relies on this power bus... but perhaps this would work?
thanks,
haima
