Variable HPF Kit
Posted: Wed Mar 29, 2023 9:25 am
by SamS
Just looking to confirm the component changes to for the 1meg input impedance and the 22hz-220hz frequency range.
Is it just R4 - 1meg and both C1,C2 - 100nf?
Any other build details available?
Re: Variable HPF Kit
Posted: Wed Mar 29, 2023 11:04 am
SamS wrote: ↑Wed Mar 29, 2023 9:25 am
For 1Meg in yes change R4 to 1Meg and use fet input opamp type like TLO72 etc
For 22-220hz use 220nF for C1 & C2. Make these caps larger to move the frequency range down.
Depends on the -dB point used as the roll-off reference point for the frequency.
Some users like the 220nF in parellel with 100nF or 330nF for C1 & C2
Feel free to ask any questions you have here
Posted: Thu Mar 30, 2023 8:00 am
by SamS
Thanks for clarifying that, I think maybe the cap values in the product information on web store are around the other way.
Posted: Thu Jun 01, 2023 11:39 am
by ofoot
So I'm a bit of a newbie to this so I apologize if I sound way out of my depth here.
I would love to make a stereo HPF and was wondering a few things before buying a few:
1) Is the 0V connection for the Sleeve of a T/S wire? I assume I'd connect both sleeves of the Input and Output wires?
2) Because this a TL072, could I just use the V+/V- of a standard 9V power supply found on guitar pedals, or would I need the full listed 18/36V difference? I've done other projects with the chip and standard 9V power worked fine.
3) is the potentiometer a 3-pin or 6-pin?
Thank you so much and thank you for making this amazing package!
Posted: Thu Jun 01, 2023 11:45 am
ofoot wrote: ↑Thu Jun 01, 2023 11:39 am
Yes both sleeves should be connected to 0v power supply common
9v is a bit low for a TL072 opamp but some will run on that but you need to make a rail splitter with 2 x 4.7v zeners to make +/-4.5v as this kit need 2 voltage rails + and -. This low voltage will limit headroom a lot. Ideally, you could use 2 x 9v batteries to make +/-9v rails which would run on fine.
6 pin dual 20k reverse log pot
Posted: Fri Jun 02, 2023 6:20 am
by ofoot
Would this DC/DC converter fit the bill? Seems to fit the voltage spec of the OP-amp and avoid the need to reinvent the wheel(also Im terrified of working on power). I think this would help a lot of other people. Thanks!
https://www.ebay.com/itm/172751512784?h ... R9SawMuOYg
Posted: Fri Jun 02, 2023 12:05 pm
ofoot wrote: ↑Fri Jun 02, 2023 6:20 am
While it would power it. It is also way overkill and likely to inject lots of noise in the audio spectrum making the HPF useless. It is a symmetrical design so Opamp may cancel most of the noise but impossible to say without trying one.
Posted: Thu Jun 15, 2023 6:23 pm
by ofoot
So I found a more appropriate PSU that converts 2-pin 12V to +12/0/-12V(massive ebay link below) and the filter works! It sounds great!
However I was wondering if you have the P/N of the older smaller caps on the previous BOM as I would like to have a higher cutoff.
I'll also experiment with a smaller pot value like 10k or something if I can find the right ones.
For anyone reading this, I am going to try to use the dedicated pin-outs at the very edge of this eurorack power supply as that is where +12/0/-12 are most common in synths:
https://www.thonk.co.uk/shop/fc-power-kit/
This power supply worked with a 12V DC power wallwart, but gave me only +/-10V because I routed the power to the remote start as well.
https://www.ebay.com/itm/172751512784?_ ... %7Ciid%3A1
Thank you all and I'll compile a github link or something to put everything in one place with pictures such.
