PEQ500A kit BUILD THREAD
Please ask any questions about building the PEQ500A on this thread
Build Map at link below with PEQ500A pcb parts assembly order.
http://www.jlmaudio.com/builds/maps/PEQ500A_map.html
Build Photos below. You must be signed into the forum to see attachments.
PEQ500A inside Top of PEQ500A PCB Bottom of PEQ500A PCB which comes with all precision SMD C0G caps & resistors fitted Break up PCB into sections with minimum flexing of the board Be careful while soldering not to damage any of the SMD parts under the PCB
There is a lot of room and not much soldering to be done so turn the PCB for best angle for easy soldering LO PCB parts LO PCB Built HI PCB Parts HI PCB Built (Cut off locate pin and solder 2 solder pads together) SWITCH PCB Parts SWITCH PCB Built EQ PCB Parts
WARNING If you have 24v relays (P24) in your kit do NOT fit them. Contact us for correct 12v (P12) relays
(screw down inductor firmly with black screw provided before soldering it in) EQ PCB Built Stick 6mm rubber foot to bottom of EQ PCB under inductor for extra support. PEQ500A Assembly
Double check you have cut of locate tab on dual 10k pot/switch
Fit HI PCB to front panel and do up the 2 x 10mm nuts tight. Bend short leg of orange LED down slightly less than 90degrees.
Then bend long leg of orange LED down slightly less than 90degrees.
The short leg will down be longer and goes in the pad closest to the front of the pcb. Fit orange LED to pcb and shelf panel hole and solder and trim legs Fit SWITCH PCB to front panel
Tighten 3mm bolt to standoff and 10mm nut to front panel Bend short leg of blue LED down slightly less than 90degrees
Then bend long leg of blue LED down slightly less than 90degrees
Cut blue tube into 2 x 10mm and fit over LED legs and trim legs to 15 to 17mm long
The short leg will down be longer and goes in the pad closest to the front of the pcb. Fit blue LED to pcb and EQ IN panel hole and solder and trim legs Fit LO PCB to front panel Fit EQ PCB to bracket and front panel and do up both 12mm nuts
Remove clear protective plastic from front of bracket first Plugin 6 pin cable between EQ & LO PCB
Plugin 10 pin 3 header cable between EQ & HI & SWITCH PCB PEQ500A ready for adding BIO500T PCB
(Do not fit Knobs until EQ is fully tested as they can be hard to get off)
When fitting knobs check all controls are fully CCW and try knobs just slightly on T18 spline to check dial lines up.
Swap knobs between pot splines until they all line up correctly before pushing them fully down the shaft.
If you need to remove a knob the break-off pieces of pcb left over are good between the front panel and a flat screwdriver
to stop marking the front panel as you lever off the knob
BIO500T PCB kit
Fully 51X and 500 compatible. 51X pins shorter so PCB will plug into 500 rack without having to cut them off.
PCB automatically uses the highest power available. +/-16v for 500 and +/-24v for 51X.
PEQ500A version of BIO500T comes with 2 x JLM99v and 12 x 1mm socket pins instead of NE5532A and DIP8 socket
BIO500T PCB.
Fit 12 x 1mm sockets for 2 x 99v opamp. Do NOT press the sockets in. Just let them sit in the holes.
Use a piece of cardboard to hold them in while turning the PCB over.
(Photo shows LA500A version with 6 sockets but PEQ500A uses all 12 sockets for 2 x JLM99v opamps instead)
Fit and solder Relay (DIP8 socket not used in PEQ500A). Make sure the POLARIZED socket matches the PCB overlay. Bend 2 legs out to hold the relay in place for soldering. Solder relay in place once POLARITY has been checked.
Caps 01.uF should be marked 104 or 0.1u or 100n. 47pF should be marked 470 or 47p. Fold 47pF caps down flat to PCB before soldering them.
Some PCB batch have had holes a bit to small, if so click link below to see what to do https://www.jlmaudio.com/forum/viewtopic.php?p=4902#p4902
Fit Transformer to PCB
Fit BIO500T PCB to Bracket (LA500A bracket shown but PEQ500A has the same rear mounting standoff to screw the pcb too.)
Setup & Testing
The 500R 25turn trimpot is for setting unity gain and matching level between pairs of PEQ500A. With a 1kHz tone, turn off the power to the 500 rack with the PEQ500A in it. The PEQ500A will go into hard relay bypass. Set reference level like 0dBu (any level will do as long as you remember it) then power up the 500 rack and switch EQ to EQ out and adjust trimpot for same 0dBu. If doing a pair make sure they are set to the same frequencies as even in EQ off it affects level slightly.
If you would like to check everything is working then with music playing set high boost to full and step though the frequencies to make sure you can hear the boost working on all frequencies. Then press BW so shelf orange led lights and step though all frequencies. If shelf is not working then check you soldered the 2 solder pads together on the HI PCB. Even in shelf the BW with change the slope into the shelf. Do this for each boost and cut. Plugin doctor set to use hardware is a perfect way to check the frequencies and there match. But if you bought a pair of PEQ500A we would have matched everything so that will be near perfect.
BIO500T PCB kit
BIO500T PCB.
Setup & Testing
Re: PEQ500A kit BUILD THREAD
Hi Joe build two of those yesterday and I'm ready for testing, is there information that I should be aware of ? I can't find any instruction following that page. Great build btw, can wait to use them.
Just finish first test, all sound great. Still wondering tho about the 500r trimpot.
Yes I did forget to mention the 500R 25turn trimpot is for setting unity gain and matching level between pairs of PEQ500A. With a 1kHz tone, turn off the power to the 500 rack with the PEQ500A in it. The PEQ500A will go into hard relay bypass. Set reference level like 0dBu (any level will do as long as you remember it) then power up the 500 rack and switch EQ to EQ out and adjust trimpot for same 0dBu. If doing a pair make sure they are set to the same frequencies as even in EQ off it affects level slightly.
Just finished my first of a pair I got and they sound amazing. I like how these have a tight and precise sound compare to my tube pultec. The "tone" is also nice. Neve-like for sure. changed the polarized electros to nichicon HE 35V 180 uf and might put small polyester film bypass capacitors on the bipolar caps.
Update,
I didn't like the film bypass caps on the bipolars so I'm going to leave them off. They made the sound a bit smeary. I do very much like the Nichicon HE's in place of the stock lelon's.
Hi there
Quick question
I’ve been supplied with 4 x P24 relays
On the parts list it says P12 amd also on PCB says P12
Just wondering is it ok to use these or has kit come with incorrect Relays
Sean
Quick question
Sean
HI Sean
Do NOT fit the 24v relays we will ship you the correct 12v ones today. Seems there are 10 kits out there with the wrong relays. Yours are 2 of them. So now to chase down the other 8.
Thanks Joe got the relays in the mailJoe Malone wrote: ↑Tue Nov 01, 2022 10:01 amHI Sean
Thanks Again
Sean
I have question regarding testing / matching the PEQ500
So im sending a 1khz tone to the 500 rack with eq inserted power off and eq set to in
I cant seem to get the trimpot to move the test tone at all.
When 500 rack power on i can adjust the level of the 1khz tone
Just wondering am i doing something wrong here
Thanks Joe
Sean
Thanks Joe
Sean
Hi Seanballo333 wrote: ↑Mon Nov 07, 2022 3:16 pmHi Joe
Thanks Joe
Sean
With power to the rack off the PEQ500A will be in hard relay bypass so the pot will not do anything as it controls the gain of the opamp which needs power.
With power off to rack take note of output level at 1khz like +4dBu etc and turn rack power on and EQ in switch to off and adjust trim pot for the same output level as with power to rack off. Done
Hi JoeJoe Malone wrote: ↑Mon Nov 07, 2022 3:48 pmHi Seanballo333 wrote: ↑Mon Nov 07, 2022 3:16 pmHi Joe
Thanks Joe
Sean
Got it all done thanks again Joe
These things sound incredible.
Sean
Hi SeanHi Joe
Sean
Cool great to hear you got it all working. Yes the PEQ500A is a very sweet EQ and the new C0G caps just make it even better
Joe.
All sorted.
Thanks for the two PEQ500A kits. I have built both kits, and am testing them with plug-in doctor. I noticed that on one of the kits only, when I turn off the eq (eq out), the low frequency boost circuit is still operating, and changing boost and frequency affects the output, even though the eq is out on the rocker switch..
The high frequency controls have no effect, including the shelf button, as expected.
The other unit works as expected.
Any assistance you can provide would be muchly appreciated.
Regards Rob
All sorted.
Regards Rob
Check you have the 12v EQ On relay the correct way around and all pins are soldered correctly. One of the pins goes to ground plane so needs more heat. So make sure all soldering has flowed properly. If not sure attach some clear well lit in focus top and bottom photos of that pcbrobranogajec wrote: ↑Mon Sep 04, 2023 2:41 pmJoe.
All sorted.
Regards Rob
