VUPPM Stereo Meter Compact Kit Build Thread
Posted: Sun May 16, 2021 8:30 am
PCB Component Build maps
Display PCB
http://jlmaudio.com/builds/maps/VUPPM50 ... y_map.html
MAIN CPU PCB
http://jlmaudio.com/builds/maps/VUPPM500_map.html
COMPACT ANALOG PCB
http://jlmaudio.com/builds/maps/VUPPM50 ... g_map.html
Test procedure Analog input
Power up VUPPM Compact with the bottom of case removed so you have access to the 4 trimpots.
Press Meter Mode and Peak Mode together to go into led test mode. This shows all green then all orange and then all red.
Press peak reset to set brightness level to LOW, MEDIUM, HIGH.
Press either Meter Mode and Peak Mode to leave led test mode.
