SUM8 Build Thread
SUM8 Build Thread
SUM8 pcb.
SUM8 BOM Parts list
1 x SUM8 PCB
4 x Dual opamp NE5532A, LM4562, LME49720, etc
2 x 18v Zener Diodes (only needed if using higher power rails or single power rail)
4 x DIP8 IC sockets
2 x right angle IDC 16 pin pcb headers
1 x 3way 5.08mm terminal block
2 x 10R carbon resistors
24 x 10k metal film resistors
16 x 47pF ceramic caps
8 x 1uF 50v mono caps
8 x 100uF 10v Non Polar caps
8 x dual or dual concentric 9mm 10k log pots
Rocinante
Re: SUM8 Build Thread
Post by Rocinante »
This is awesome.
znjamznjam
Post by znjamznjam »
Can we get what more info? Shematic and wiring?
znjamznjam
Hy i have recived pcb.
Can i get more info about this sum:
Which ic is used
Is er mouser or anders part number for 16pin plug and cable
Is there list for parts in this project?
Thanks in advance
znjamznjam wrote:
Sat Jun 05, 2021 8:21 pm
Which ic is used
Thanks in advance
Added SUM8 schematic & BOM to first post
You can use any dual opamp like NE5532A, NE4562, LME49720, OPA2134.
znjamznjam
Thanks :D
