Page 1 of 2
AUX8 Build thread
Posted: Sat Nov 14, 2020 10:22 am
Notes and Errata Ver 1 PCB.
AUX8 BOM Parts list
1 x AUX8 PCB
2 x right angle IDC 16 pin pcb headers
9 x 2way headers
8 x 10k metal film resistors
2 x 820R metal film resistors
8 x dual or dual concentric 9mm 10k log pots
Re: AUX8 Build thread
Posted: Tue Nov 24, 2020 2:16 am
by fragletrollet
Posted: Tue Dec 01, 2020 12:17 pm
fragletrollet wrote: ↑Tue Nov 24, 2020 2:16 am
Thanks for posting Magnus
Posted: Wed May 05, 2021 5:02 pm
by znjamznjam
Hy Can you post fpd i really like you design.
Can you also make more pictures of wiring?
Can you also use direct bus out without summing to one stereo out from summing?
This is great diy but very little info about.
Thanks in advance
regardes
Neno from NL
Posted: Wed May 05, 2021 9:04 pm
The AUX8 and SUM8 pcb is a 8 channel mono or 4 channel stereo depending on pots used with active virtual ground summing and 8 channel mono or channel aux master with inverting stage. So basically it can do 8in x 8out matrix. The pcbs are unbalanced in and out but if you use our palpigrade and tradigrade kits they plug in and give balanced in and out on DB25 Tascam standard.
Posted: Wed May 05, 2021 10:00 pm
by znjamznjam
Hy
Thanks for info. If I order pcb's do I get what info (schematic for wiring etc)
regardes
neno
Posted: Sun Jun 06, 2021 8:02 pm
AUX8 & SUM8 Schematics now on each thread
Posted: Sun Sep 12, 2021 11:45 am
A great example of the type of mixer that can be made with AUX8 & SUM8 at the link below
https://www.jlmaudio.com/forum/viewtopic.php?f=2&t=342
Posted: Fri Mar 04, 2022 12:39 am
by fragletrollet
Finished panel design and got my panel cnc'ed and delivered. Still have some work to do before the unit is all finished, but I can verify that my panel design fits with my selected components and pcb's.
Posted: Fri Mar 04, 2022 12:43 am
by fragletrollet
More pictures.
Posted: Fri Mar 04, 2022 12:47 am
by fragletrollet
Holes in the last slot are in my design supposed to fit a
label strip for labeling the destination of each aux bus. The strip will need cutting and drilling, I've yet to do this. Holes can also be used for signal/overload LED's, but the holes are a little too small for 3mm led's (initially designed for m3 screws). I'll probably use the middle hole for an overload led fitted behind the strip and the ones on either side for strip mounting.
Posted: Fri Mar 04, 2022 12:52 am
by fragletrollet
Panel design files. Go crazy!
Posted: Fri Mar 04, 2022 1:01 am
by fragletrollet
I'm going for these knobs.
Posted: Fri Mar 04, 2022 1:02 am
by fragletrollet
Posted: Fri Mar 04, 2022 1:14 am
by znjamznjam
Nice, looking good.
