MichaelGNunn wrote:
Sat Apr 17, 2021 5:03 am
Post Mon Apr 12, 2021 1:18 am
MichaelGNunn wrote: ↑
Hi Joe, I got everything together on my dual 99V and it sounds great aside from some noise issues! I looked through the forum, and it seems someone else has had this issue. It sounds like some electrical interference or grounding issue. can this be fixed by getting a power conditioner that separates my analog equipment from digital equipment computer, or do I need to open it up?
MN
HI Michael
Do you have a sample of the noise you can send me with nothing connected to the input of the mic pre?
I posted a broken link. This one should work! This is with all three knobs turned all the way right
https://soundcloud.app.goo.gl/nN99k1SjcBRZNMuW7
HI Michael
What A/D are you running this into ? Is it setup for pro level +18dBu to +24dBu clip level?
MichaelGNunn
Post by MichaelGNunn »
Mon Apr 19, 2021 9:21 am
MN
HI Michael
HI Michael
I’m running an apollo x8p, It was on +20 dBu, I can change it to +24 dBu
Ok +20dBu is perfect. Is the noise the exactly the same in both channels?
Does the noise stop instantly when the power switch is turned off?
Can you email me internal photos and power supply photo so I can check the build over.
mhelin59
Post by mhelin59 »
Is it OK to have another op amp soldered under the DOA if the IC1/A (pins 1,2 and 3) are lifted and connected appropriately when using the BA (basic) PCB? That way you could for an example drive a balanced transformer like LL1539 (though without mixed feedback). Obviously with the output caps as the output has "some" DC (the LL1539 datasheet shows DC connected circuit meant for dual supplies).
mhelin59 wrote:
Thu Jun 17, 2021 6:11 am
It could be done but the drive between discrete and the dip8 half running inverted wouldn't be even so there is no benefit.
I would just run both primaries in parallel from the +out and return to 0v as with discrete opamp this will be easy to drive and give max headroom
mhelin59
Post by mhelin59 »
Thu Jun 17, 2021 11:58 am
Ok, that's also what I was afraid of, that the two outputs wouldn't be symmetric enough, will use just the DOA output, thanks.
Sam
Post by Sam »
Hi I've just finished one half of my BA2 2 CH Rack Kit
I'm just doing some testing and all seems well except when I wind up the gain, I'm getting a fair amount of power supply noise, more when the phantom power is engaged. I'm just not sure if I've missed something or my lead dressing is just bad. I've attached a photo.
Sam
Sam wrote:
Fri Aug 27, 2021 3:25 pm
Sam
HI Sam
The new black pcbs are supposed to be fully built and should have BD681 and trimpot fitted. We adjust the trimpot so you have about 44v at +v of the opamp as this forms a linear smoothing regulator for each mic pre which I think is the main problem here.
Build looks very neat but you need to keep your gain and impedance wiring as short a possible so I would shorten them down so they only have a bit of slack especially the impedance wiring. Also twist the ribbon cable so it forms a tight tube between the IDC headers.
Sam
Post by Sam »
Fri Aug 27, 2021 3:47 pm
Sam
HI Sam
Hey Joe, thanks for the quick response. Right, I took the wrong approach when referencing the tables at the start of the thread.
Will fit them and make the adjustments and report back.
Sam
Post by Sam »
Sam wrote:
Fri Aug 27, 2021 4:06 pm
Sam
HI Sam
Fitted and adjustments made. It has made a huge improvement. There's still a little power supply noise when the gain is wound up past 3 o'clock but I'm probably not being too fair to it considering I'm just running to a line in on a basic amp while testing.
Sam wrote:
Fri Aug 27, 2021 5:03 pm
HI Sam
Remember with nothing plugged into the input transformer it will pick up noise. So the best test is with nothing plugged into the input and pad on. Do the second channel and see how they both work with a mic input.
Sam
Post by Sam »
Sat Aug 28, 2021 2:55 pm
Hey Joe, I had a chance to get back to it today, I finished off the other side, tested and compared. It has a pretty low noise floor, the power supply noise seems to not be an issue so long as the unit is always on and since it's connected via my patchbay, it stays quiet. So I'd say I probably built it OK
I gave it a quick run with some mics and ran a couple tests, the channels seem to be matched well enough for stereo recording straight up and playing bass DI and adjusting the impedance sounds great.
Now that I've got it in my rack, I'll start tracking through it tomorrow. Just out of curiosity, would it be possible to fit an output trim to the BA2? it would be nice to really drive that input transformer! - I could always pad it after the output if I needed to though.
Great kit - simple to build and sounds great! great bang for the buck! Thanks!
Sam
Sam wrote:
Sun Aug 29, 2021 8:27 pm
Sam
Cool great to hear :-)
Adding an output pad only allows you to overdrive the output transformer if you have them fitted which is not as nice as just driving the input without the pad on.
Osse87
Post by Osse87 »
Hello guys, first post here by me, I hope this is the right place for my post. I built a two channel BAD a few years ago and one of the channels have developed a high noise floor since quite some time ago. I think I diagnosed it to one of the OPA2604 that has gone bad as it turns VERY hot within like 10 seconds of powerup. I wonder if there are any direct replacement IC's out there as these seem to not be available anymore? I'm using the small 48v powersupply. I was thinking of the NE5532AP but looks like I'll have to add some zener diode also if going this route.
I'm not totally foreign to converting it into a single IC unit if it's possible to bypass one of the IC sockets either, I rarely need this much gain on tap anyhow. As I've got 3 working OPA2604 I could use one in either unit, and install for a dual in one of them in the few cases where I need the extra gain, is this feasible?
Best,
Ossian
Osse87 wrote:
Sat Jan 22, 2022 9:37 am
Best,
Ossian
Swap OPA2604 between channels to see if the fault follows the opamp or stays with the channel. If you need a OPA2604 I have some. But do the swap test first and let me know what you find here.
