What to run the most BA BAD BAN mic pres on the smallest MEPS SMPS power supply please read the Notes and Errata further down this page[/size]
NEW BLACK BA Ver2 PCB
Complete circuit of JLM Baby Animal Ver2 Black PCB here
Note: Build same as old BA PCB except Zpot now has its own 2 pin connector connector and series resistor for Zpot is fitted to Rload on black pcb.
If fixed Z then wire link over 2 pin connector solder pads.
BA PCB
Complete circuit of JLM Baby Animal PCB here
Circuit for Baby Animal Mic Pre with JLM14 & OPA2604 here
Circuit for Baby Animal Mic Pre with JLM14 & JLM99v or Hybrid here
BAD PCB
Complete circuit of JLM Baby Animal Dual PCB here
BAN PCB
See BAN build thread here
The BA & BAD PCB are easy to assemble with all parts with there value marked on the PCB needing to be fitted. Parts marked with * or # and zener diodes are only needed if running on higher than 48v or running opamps that need less then the +/-24v to run on. Parts with a name like Rload, CLoad, Rzobel, CZobel, RPad, RGain need to be selected to match the input transformer and opamp used. Their values for projects like the Dual99v can be found on the overlay sheet for the project.
Original 48 page BA thread on GroupDIY
https://groupdiy.com/index.php?topic=15245.0
Condensed version of The Lab Thread on JLM forum
http://www.jlmaudio.com/forum/viewtopic.php?f=2&t=11
BA, BA2, BA4 Overlay wiring PDF Large PDF copy here
Dual99v, BAD Overlay wiring PDF Larger PDF copy here
BA BAD BAN voltage settings
BA Settings (Ratios higher than 1:6.45 below not recommended unless using 50ohm microphones)
Building API 512, API 312 type mic pre on BA PCB
If using JLM25HV or JLM25HV FET NO BD681 is needed & 33v - 39v zener as they can run direct on the +/-24v of the BA PCB.
Cinemag CM-75101APC on BA PCB
Notes & Errata
DO NOT DO THIS SOFT START MOD TO ANY NEW BUILDS. If building 3 or more BA kits use our 48v 40W SMPS instead as it can run 8 BA BAD or BAN easy
BA MEPS SMPS Soft start mod (DO NOT DO THIS SOFT START MOD TO ANY NEW BUILDS. If building 3 or more BA kits use our 48v 40W SMPS instead as it can run 8 BA easy)
BAD MEPS SMPS Soft start mod (DO NOT DO THIS SOFT START MOD TO ANY NEW BUILDS. If building 3 or more BAD kits use our 48v 40W SMPS instead as it can run 8 BAD easy)
BAN MEPS SMPS Soft start mod (DO NOT DO THIS SOFT START MOD TO ANY NEW BUILDS. If building 3 or more BAN kits use our 48v 40W SMPS instead as it can run 8 BAN easy)
Some helpful photo's (If there is some detail you need a photo off let me know and I will add it here)
BAD PCB fully assembled except for 2 x 270R for RGain, input transformer and opamps Larger photo here
Notes & Errata#BD681 jumper is wrong in the photo below. Should be E-C. Also Dual99v does not use a Cload cap any more. So leave blank.
BAD PCB fully assembled as Dual99v (Note 2 links needed between centre pin and E on each BD681 position and 1mm gap under transformer)
Sit toggle hard against the PCB and solder one front support leg on each toggle to hold in place.
Check toggles level and square to each other and solder all legs and support pins
Dis-guard flat washer and fit the rear nut (should be a few mm gapped from the end of the thread) and washer to all three toggles
Nuts should just screw on an tighten with minimum thread sticking out if the rear nut is set correctly
Nuts and washer order for Power switch
Same again space the rear nut up so the minimum of thread sticks out past front nut.
DC connector and Fuse wiring
All Pot wiring for BAD Dual99v PCB
Gain pot wiring (Photo shows BAD/Dual99v dual pot)
Note BA is the same but only a single pot
Output Pot wiring
Z pot wiring
OEP/VTX = 10k in series with 100k log pot. (As shown in photo below for Dual99v)
JLM14 = 2k2 in series with 50k log pot (2k2 resistor solders to both pins on the left and red wire solders to all 4 pins on the right)
Output transformer to IOXLR PCB (Note link wire between -2 and +3 is hidden in this photo)
Full Dual99v internal wiring Larger photo here
[img]http
