NV500 Mic pre BUILD THREAD
ballo333
Re: NV500 Mic pre BUILD THREAD
Post by ballo333 »
Hey Joe
So sorted all out pre is all working sounding sweet
New red 48 LED is fine but the blue DI still nothing
So i checked inside the chasis and the blue led was working but very dim
So i checked my other NV500 pre built one and realised it has a FLAT blue LED like it says on BOM lol
So yeah the one suppled was a round blue one and the one i replaced a clear round blue one is faint still
Also ill show in pictures my other NV500 has what looks like foil on the back of DI? The one i built has nothing there not sure if that makes a difference?
My local Jaycar had no flat blue LEDS
Thanks Sean
hasanova
Post by hasanova »
I'd like to use my JLM pre-amps for LINE-IN (24 channel mixing - 500 series) by using an inline U-PAD on the inputs.
I'm a bit concerned about phantom power.
Some of the mic/line pre's I have defeat +48V on the inputs when switched to LINE-IN, but the JLM ones don't have LINE IN. For some other micpre's it's just a matter of removing the cap on the switch and it becomes impossible to depress it with a finger (!).
I know it's a lot discussed topic, but I' don't need it at the moment and I have external phantom boxes for mic's that need it. I'm not looking for or interested in phantom-blockers.
Instead of removing the switch completely, is there an easier way like by removing some resistors, and replace by holders. So it becomes easy to reverse later.
I ask for the NV500 (and if possible also TG500)?
Thanx!
hasanova wrote:
Sun Jun 29, 2025 4:28 am
Thanx!
All of our mic pres can handle +24dBu line input when the pad is switched on the front panel. Leave 48v switched off on the front panel.
If you want to disable 48v phantom power on NV500, TG500, Dual99v500 just remove or lift one end of the 48v 10R resistor next to the 48v rear edge connector pin 15.
You can add a external U pad using 2 x 470R with 51R to 100R depending on the amount of attenuation you need. Then the internal pad can be turned off.
hasanova
Post by hasanova »
:D :D :D :D :D Thnx Joe!
hasanova
Post by hasanova »
I have 2 units. #2 is working fine, but #1 has no output signal from GAIN setting 60dB and up.
FYI: I have have disabled phantom power by lifting one leg of 48V resistor (10R).
hasanova
Post by hasanova »
I've removed parts to get an as clear as possible view for the pictures.
hasanova wrote:
Thu Aug 28, 2025 6:36 pm
Schermafbeelding 2025-08-28 om 10.29.26.pngSchermafbeelding 2025-08-28 om 10.30.02.png
Ok first if you swap the 2 BA283AV cards does the gain work the same to 60dB or does the problem change ?
If the problem stays the same then the problem will be to do with the 5v reed relay and the 5v1 and 1N914 diode. So Check both diodes are correct way around. You should have 5v across the 5v1 diode ? and above 60dB you should have 5v across the 1N914 ? on the other side of the reed relay. Let me know what you find
hasanova
Post by hasanova »
Yes, it was D3 (1N914 or 1N4148) that was wrong way around. Now #1 can go max gain also.
Thank you!
hasanova wrote:
Fri Aug 29, 2025 2:13 am
Thank you!
Cool great to hear it was a simple one. Enjoy :D 8)
ponyboyrustylee
No mic input
Post by ponyboyrustylee »
NV500 was up and working fine... and sounding great. I've used both the mic input and DI input. Today, the mic input stopped working. Phantom power light is working but signal isn't coming through, even if I try a dynamic mic that doesn't need phantom power. DI is working fine so I know I'm patched in correctly.
Can you provide a schematic so I can follow the signal path through and see where the broken link is and/ or, what is your suggestion in this case? Suspect parts or solder areas?
Thank you
Rusty
Re: No mic input
ponyboyrustylee wrote:
Mon Mar 16, 2026 7:23 am
Thank you
Rusty
HI Rusty
If the DI input works then it can only be the soldering on the 7 pin DI connector on the main pcb or the 7 pin socket on the DI pcb or 9 pin DI socket soldering or DI socket switch has failed. It is very rare for the switch to fail. You can fit 2 jumpers to the main pcb as shown by links in the photo below to test the mic pre input works without the DI pcb fitted. If you have no jumper shunt you can solder those pads together under the pcb instead but remember to remove the solder links before refitting the DI pcb. If you get stuck send me some photos of the top and bottom of the DI pcb to check over for you.
ponyboyrustylee
Back up and running, thanks for the advice! :D
I swapped my DI board from my other NV500 in and that solved the problem.
I did more troubleshooting and found the switch is indeed bad. When measuring continuity from 3-4 and 6-7 on J7 only 6-7 ring through and 3-4 do not with nothing in the plug.
Also, with the DI unit held with the jack pointing up, component side down, the top 2 right side pins on the switch do not ring through to each other but each individually rings to J7 3-4.
So the switch isn't making connection internally, at least not consistently. I retouched all the solder pads associated with the switch and J7 for safety to no avail.
Next question:
I don't have the proper desoldering station to be able to remove that switch successfully. Any chance I could get a new DI board kit? Or do you have another idea?
Thank you
Rusty
ponyboyrustylee
Tue Mar 17, 2026 4:15 am
Next question:
Thank you
Rusty
Sorry found I had left this open in a tab and not finished posting this :oops:
email sales@jlmaudio.com so we can work out what and where to send.
kellyad33
Post by kellyad33 »
Just finished 2 of these NV500's. Great build 👍
I'll play with them a bit more today, but tested them on drum overheads and they were really dark (spaced pair).
When I say dark I mean the toms were coming through strong but could barely hear the cymbals, so really strong bottom end but super weak top end with the mics mainly pointed at cymbals.
The impedance knob does affect the signal and makes it slightly brighter, but still sounds strong strongly shelved over say...2khz
Joe is there anything obvious that you can think might be wrong?
I'll test more today to.get a better idea though.
