Passive Controller Build Thread
Re: Passive Controller Build Thread
So the PIN numbers on the bottom of the switch don’t matter? Btw - I’m using a Lorlin rotary switch.. I had oriented the switch so the inner row of pins had the A pin at 12 o’clock
Mjwever wrote:So the PIN numbers on the bottom of the switch don’t matter? Btw - I’m using a Lorlin rotary switch.. I had oriented the switch so the inner row of pins had the A pin at 12 o’clock
OK the PCB is made for open metal frame alpha switches but the lorlin if the pin out fits the pcb should work fine and not matter which of the 4 ways it will fit.
Thanks so much Joe. Really appreciate it
Users browsing this forum: No registered users and 6 guests
