hyped
Postby hyped » Sun Feb 05, 2017 9:41 am
Thanks for feedback appreciated mate.
Will do
hyped
Postby hyped » Fri Feb 24, 2017 10:09 pm
HI Joe,
Well I got it working with a 1/4 jack so it must have been dodgy connections with RCA. Just wanted to confirm that using the on board connections for audio in. Live to non inverting, and rca and does that connect to both inverting and gnd/shield?
Or just shield?
thanks mate
Postby Joe Malone » Sat Feb 25, 2017 9:03 pm
hyped wrote:HI Joe,
Yes correct
hyped
Postby hyped » Mon Feb 27, 2017 2:53 pm
Thanks Joe appreciated
I'll take the rca gnd to both inverting and shield
jdirolf
Postby jdirolf » Mon Sep 11, 2017 8:07 am
Greetings,
Is unregulated DC ok for this kit? Would be around 24v (before being split by the onboard voltage divider).
Thanks in advance,
Jared
Postby Joe Malone » Mon Sep 11, 2017 10:42 am
jdirolf wrote:Greetings,
Thanks in advance,
Jared
Yes unreg will usually work for good level inputs where gain trim is not fully up. And since it is 24v this also helps.
jdirolf
Postby jdirolf » Mon Sep 11, 2017 11:42 am
Great- thank you!
tsip
Postby tsip » Tue Feb 20, 2018 8:57 pm
i cant seem to get my vu meter work properly.i can only manage very small movement of the needle,barely visible and not sure why. the meter is a componex c450 and is connected to the buffer from the source which is a chromecast for audio device.dc is 19v. any ideas as to how to troubleshoot?many thanks
Postby Joe Malone » Wed Feb 21, 2018 10:05 am
tsip wrote:i cant seem to get my vu meter work properly.i can only manage very small movement of the needle,barely visible and not sure why. the meter is a componex c450 and is connected to the buffer from the source which is a chromecast for audio device.dc is 19v. any ideas as to how to troubleshoot?many thanks
HI Tsip
Email me some photos of your pcb build and wiring and VU meters so I can work out what the problem is.
Postby Joe Malone » Tue Feb 27, 2018 11:29 am
HI Tsip
HI Tsip
From your photos and email. Since you are sharing power supplies you have to be careful how each unit uses that power supply. Since the VU buffer and amp are sharing the same power supply make sure you do not connect the 0v to the input of the buffer. Only use the +in and connect -in to 0v and nothing else otherwise you will short out the power in the buffer. So only connect 3 wires to the VU buffer +V & -V & +in. (-in linked to 0v terminal next to it and do not connect to nothing else)
bOTLJC
Postby bOTLJC » Tue Apr 03, 2018 4:53 pm
Joe Hello
If I power the buffer on 12 volts will it be enough to have the Led illuminate at a +14 dbu peak?
John C
bOTL Audio
Postby Joe Malone » Mon Apr 16, 2018 8:10 pm
bOTLJC wrote:Joe Hello
John C
bOTL Audio
Since +14dBu is roughly 11vac peak to peak it would be very close but 15v to 24v would be better for bit of headroom
JimSalabim
Postby JimSalabim » Mon Apr 30, 2018 3:43 am
Hi! Is XLR 1 sharing the same ground as the rest of the circuit?
Postby Joe Malone » Mon Apr 30, 2018 12:32 pm
JimSalabim wrote:Hi! Is XLR 1 sharing the same ground as the rest of the circuit?
This kit has no XLR? So you may mean the VU2 kit? But Yes both the VU2 XLR pin 1 and Yellow wire on this VU buffer kit connect to the black 0v of the +12v to +30v power supply. This is needed as most plug pack power supplies are fully floating so have no other reference to the pin1 or audio ground.
JimSalabim
Postby JimSalabim » Mon Apr 30, 2018 9:21 pm
Thank you very much! Good to know! No, I don’t have the kit, I was looking at the PCB only (the one for VU Buffer & Peak LED).
Users browsing this forum: No registered users and 2 guests
