Yes, unfortunately still no joy, same symptoms. Voltage is 0.002v across the left meter leads, and 6.22v across the right. Turning the pot has no effect. I'm not sure exactly how these pots work, do they have stops on either side of the range? I can spin mine more than 24 turns in either direction, maybe I broke the pot somehow during install or setup? Or maybe that's normal? If I go too far CW I hear a soft click once a rotation, I'm assuming that's the top of the range?Joe Malone wrote: ↑Wed Feb 24, 2021 1:29 pmVoltages are correct. Have you retried the pcb since cleaning it? Also first turn the trimpot back 25 turns encase you have one on full gain. With no meters connected measure volts across +M- on both sides and let me know what volts you read?
Stereo VU meter kit BUILD THREAD
verticalmammal
Re: Stereo VU meter kit BUILD THREAD
OK the 10uF cap on that side should be blocking the dc so may have a solder short under it. Remove the 10uF and retest the +M- to check the DC is gone or not? With cap removed should be 6.2v on + side and 0v other - side of cap pads.verticalmammal wrote: ↑Wed Feb 24, 2021 2:45 pmYes, unfortunately still no joy, same symptoms. Voltage is 0.002v across the left meter leads, and 6.22v across the right. Turning the pot has no effect. I'm not sure exactly how these pots work, do they have stops on either side of the range? I can spin mine more than 24 turns in either direction, maybe I broke the pot somehow during install or setup? Or maybe that's normal? If I go too far CW I hear a soft click once a rotation, I'm assuming that's the top of the range?Joe Malone wrote: ↑Wed Feb 24, 2021 1:29 pmVoltages are correct. Have you retried the pcb since cleaning it? Also first turn the trimpot back 25 turns encase you have one on full gain. With no meters connected measure volts across +M- on both sides and let me know what volts you read?
verticalmammal
Dude, you are a genius. I could see the solder bridge on the bottom when I removed it. Zipped it off with my iron and now we're right as rain. I'd like to make a small donation to the charity of your choice as a show of thanks, let me know who you'd like it to go to.Joe Malone wrote: ↑Wed Feb 24, 2021 2:54 pmOK the 10uF cap on that side should be blocking the dc so may have a solder short under it. Remove the 10uF and retest the +M- to check the DC is gone or not? With cap removed should be 6.2v on + side and 0v other - side of cap pads.
Cool great to hear that got it workingverticalmammal wrote: ↑Wed Feb 24, 2021 3:21 pmDude, you are a genius. I could see the solder bridge on the bottom when I removed it. Zipped it off with my iron and now we're right as rain. I'd like to make a small donation to the charity of your choice as a show of thanks, let me know who you'd like it to go to.Joe Malone wrote: ↑Wed Feb 24, 2021 2:54 pmOK the 10uF cap on that side should be blocking the dc so may have a solder short under it. Remove the 10uF and retest the +M- to check the DC is gone or not? With cap removed should be 6.2v on + side and 0v other - side of cap pads.
Charity link below thanks.
https://donateplanet.com/charities/read ... in-cancer/
verticalmammal
Done and done. Super-impressed with how you honed right in on the issue with your troubleshooting steps. I had my suspicions about the caps on that side as I mentioned (although it was for the wrong reason), but even if I maybe could have found it on my own eventually, I definitely couldn't have figured it out anywhere near as fast as you did. Between that and the help you provided me with my order this donation is the least I can do. Thanks again.Joe Malone wrote: ↑Mon Mar 01, 2021 9:37 amCool great to hear that got it working
Coolverticalmammal wrote: ↑Mon Mar 01, 2021 12:01 pmDone and done. Super-impressed with how you honed right in on the issue with your troubleshooting steps. I had my suspicions about the caps on that side as I mentioned (although it was for the wrong reason), but even if I maybe could have found it on my own eventually, I definitely couldn't have figured it out anywhere near as fast as you did. Between that and the help you provided me with my order this donation is the least I can do. Thanks again.Joe Malone wrote: ↑Mon Mar 01, 2021 9:37 amCool great to hear that got it working
Cfeedback
Yes, you're right, I would never have stumbled over it so quickly.Joe Malone wrote: ↑Wed Feb 24, 2021 7:34 amCool great to hear that fixed it. When you have 2 power supplies like this you have to reference them to each other.
I will remember in any case if I should have such a problem again.
The subject of ground loops is sometimes really complex, I think.
PS: The JLM AUDIO website/shop/forum is really first class, and very interesting.
And your know-how is remarkable.
Many Thanks and stay healthy
mobtownstudios
Hi all!
The VU build was fun and relatively easy!
I have not been able to get the LEDs to light up. There is voltage headed there which I am metering at 11.57v on each LED tap.
Any idea why they are not lighting up?
The VU meters themselves are working wonderfully, however.
Thanks!!
Thanks!!
Hi Mat RLamp for the 5v led backlight is 680R. You have fitted the 10R option for meters with lamp backlight. Meter backlights should have been very bright for a second or two before burning out. If not hopefully you have the lamp wires reversed. Change to 680R first before reversing if that is the problem.
mobtownstudios
Update:
Looks like I miss this instruction.
The 2 x RLAMP resistors = 680R for new 5v LED Lamp meters and 8 x diodes are NOT fitted just 4 wire links as shown.
So I fixed that, but the voltage on the LEDs still clocks in at 11.57v.
Are my LEDs blown? Or just not getting the right voltage?
Hi Mat posted at the same time as you see above post.
mobtownstudios
Thanks Joe for replying!
Yeah, no luck there with the new resistors and diode removal with the 4 jumpers. I tried a continuity tester with the LEDs and they appear to be blown.
Would these be good replacements LEDs?
https://www.amazon.com/Adafruit-Accesso ... B00XW2MY84
All this soldering is fun! Wish I had more kits to build!
Is that voltage of 11.5v correct?
Hi Mat yes they look fine. Any 2 clear white 5mm led around 1000mcd or more will work in there with the 680R. Each led has about 2.5 to 3.5v across it. So voltage at terminals will be 5v to 7v as the 2 are in series. They maybe brighter or duller so RLamp can be changed afterwards to make brighter down to 470R or duller up to 2k. Mount them exactly the same way as they are in the back of the meters. They have a polarity which is easy to see internally in the led as they are clear.
Continuity testing doesn’t really work with the leds. If you tried the reversing of the lamp power wires with no luck then they will be dead. But they should have been very bright for a couple of seconds if they burnt out.
mobtownstudios
Yes. Very bright then turned/blew out.
I measured 12v at the led terminals. Is that acceptable?
mobtownstudios
Thanks Joe!Joe Malone wrote: ↑Fri Apr 09, 2021 9:36 amHi Mat yes they look fine. Any 2 clear white 5mm led around 1000mcd or more will work in there with the 680R. Each led has about 2.5 to 3.5v across it. So voltage at terminals will be 5v to 7v as the 2 are in series. They maybe brighter or duller so RLamp can be changed afterwards to make brighter down to 470R or duller up to 2k. Mount them exactly the same way as they are in the back of the meters. They have a polarity which is easy to see internally in the led as they are clear.
New LEDs and fixing the resisters/diodes did the trick! Glowing wonderfully!
If I wanted to use 1 LED in each meter for a gentler glow would I have to do anything else other than that? Would I need a resister anywhere in the chain?
