PaulQ wrote:Hi Joe
I put links between P+ to S+ and and one between P- to S-
The di is working but very distorted .The mtrs not moving .The pad is working
The mic is not working
You should read 12 to 15R between P- & P+ terminals next to the transformer ribbon header on the BA500 PCB =4.33
You should read 24R to 30R between S- & S+ terminals next to the transformer ribbon header on the BA500 PCB = 3.3
You should read 24R to 30R between the edge connector pin 2 and pin 4 (pin 1 starts closest to the JLM Logo next to output transformer) = 3.4
Thanks Paul
Those readings are only for when a output transformer is fitted. So don't mean anything if one is not fitted. Best to email me some photos of your build to look at so I can check it over for you.
