Regurgitator kit Build Thread
catface wrote:
Thu Oct 13, 2022 8:12 am
Would the NE5532a be the opamp of choice if you were to make a single +24V out circuit?
and if you were daisy chaining 4 boards together via J1+J2 would the 12v zeners on the other 3 boards be replaced by 1uf mono caps?
What would the 2x 10r need to be for that set up?
If that 24vdc is floating and not used by anything in a different way that will work to make +/-12vdc.
It is best to fit 12v zeners to all pcbs as they each have 10R + 100uF RC filters so best to reg each pcb with zeners.
Yes NE5532A is good for this build
Alex1990
Post by Alex1990 »
Hi - I just would like to check if this kit is appropriate for bringing re301 space echo output (2.5k output impedance) directly into patchbay/interface using approx 18db of gain. Looks like it but I’m slightly confused as there’s a quite a few things available like the dingo/dingo pup and I’m not clear 100% on the best kit for the job. I also have an old rackmount Yamaha synth that I would like to boost/balance before entering the line-in of a pre amp. Would the regurgitator work in this instance as well?
Many thanks!
Alex1990 wrote:
Wed Nov 15, 2023 9:14 pm
Many thanks!
Yes regurg will work and ideal for mono output. Also for stereo or dual output the Stereolab would work well.
Alex1990
Post by Alex1990 »
Yes brilliant as I suspected thank you. A dumb question - would you supply all components necessary to populate a double/quad board - the price doesn’t seem to change between single and quad so a bit confused.
Alex1990 wrote:
Sun Nov 19, 2023 8:48 pm
HI
You need to order as many single-parts kits as you need and then pick how you want the pcbs
For example if you order 8 kits and select Dual PCB you will get 4 Dual PCB or if you select Quad you will get 2 x Quad PCB
