[/quote]
Check the BA is fully working with NE5532A and input reg voltage is set to +30 to +36vdc on +V of the opamp sockets. If so you should be able to remove the NE5532A and fit 6 sockets and plug in the discrete opamp. Remember the discrete opamp is only driving the +out so link on dip socket is needed to put -out to 0v so quasi balanced out works.[/quote]
Opamp voltage is 24,1 and I guess that is ok because the Soun Skulptor sk99 is 24v op amp. I just need to clarify what exactly needs to be connected? 0V opamp socket to -output of the line output? Did I understood this correctly?
Thanks![/quote]
If sk99 is +/-24v you want the reg linked over so you have +48v on +V pin as the BA uses this 48v as +/-24v but 0v is referenced to -24v.
Hi, Thank you for information!
I was wondering what is the output impedance of the unit. With JLM14 input tranfo and NE5532A op amp. Does DOA change output impedance?
ylinjohto wrote:Hi, Thank you for information!
Balanced output impedance with NE5532A or discrete opamp no output transformer using +out and -out is 102ohm if using 51R or 66ohm if using 33R.
Users browsing this forum: No registered users and 0 guests
