kolchek
Post by kolchek »
An ignorant question: I’m guessing that if i wanted to pad more than 20db the solution isn’t just increasing the value of rpad? Thanks.
kolchek wrote:
Tue Jun 20, 2023 8:05 pm
If you want to pad more dB make RPad value smaller. Like in Dual99v on BAD PCB we use RPad = 51R to make 26dB pad.
kolchek
Post by kolchek »
Wed Jun 21, 2023 10:31 am
Great. Thanks Joe.
pkuchar
Post by pkuchar »
Hi folks, got a question about the 111dc circuit boards, do any of the resisters need to be fitted? I built a BA4 with jlm 14 inputs 99v opamps and 111dc output transformers. with the 48v 25 watt power supply. They are all working but I'm getting a pulsing from the power supply. The leds get dimmer then brighter and I get an audible click. Should I upgrade the power supply to the 40 watt version?
thanks,
Peter Kuchar
pkuchar wrote:
Sun Feb 18, 2024 1:09 am
thanks,
Peter Kuchar
HI Peter
No resistors need to be fitted to the 111dc pcbs. Only 10 pin header, terminals, transformer, and XLRs
The 25w with modern black BA pcbs should boot up fine and run with a better noise floor than a 40w as long as the BD681 soft start transistor was fitted to each pcb. The hiccup mode is the protection mode for the power supply.
A good idea is to test each BA pcb one at a time on power by removing the 48v wire from the other 3 pcbs. Just to be sure they all power and work fine. Then power a second and then a third and four pcb.
Feel free to put up or email some photos for me to check over
pkuchar
Post by pkuchar »
I did fit transistors, trim pot and wired the transformer correct. I'll try to power them one at a time like you suggest.
thanks,
Peter
pkuchar
Post by pkuchar »
My voltage was running a bit high. 47.5 volts in and 24.75 out or so on all 4 pres', So I dialed the volts back to about 46.5 in and around 24.33 out and that was enough to get the power supply out of hiccup mode. now all 4 preamps are running smoothly and sounding great! I was going to use them on my 4 toms, now the highs are so smooth they sound great on overheads and guitars. Love the impedence pot, cymbals sound great! One thing is I don't have continuity with zero volts and the case, no noise, should I scratch off some paint where the dc jack connects?
Peter Kuchar
pkuchar wrote:
Fri Feb 23, 2024 10:56 pm
Peter Kuchar
Cool great to hear you got them all going and like them :-)
If you are having trouble with the dc barrel linking the chassis to 0v. We just add a wire from the dc connector 0v to where the side bolts onto the back panel next to it so the 2 screws there link it to the chassis. If the BA4 rack is bolted into a rack frame then it will also get chassis ground from the other gear in the rack so usually it doesn't matter as look as the audio has good quiet noise floor
caoimhin
Post by caoimhin »
Building a pair of BAD with JLM14 and JLM2503, and I want to add a 'ratio switch' for the output transformer for 1:1, 1:2, 1:3.
Can I do an idiot check that it's o.k. to just use a 3 position rotary switch like this?:
caoimhin wrote:
Tue Mar 12, 2024 8:45 am
Yes that is correct :-)
caoimhin
Post by caoimhin »
Photos or it didn't happen, isn't that what they say? Delighted with how this turned out, thank you so much Joe!
caoimhin
Post by caoimhin »
up close
caoimhin wrote:
Tue Aug 19, 2025 3:48 am
Wow that looks great :-) Nice knobs and layout.
Great to hear you got it all working 8)
