Go Between LED values
substitute
Post by substitute »
Hey folks,
I lost the led that came with one of my Go Between kits does anyone know their operating voltage? How bout the size?
thanks!
chrisp
Re: Go Between LED values
Post by chrisp »
The 48V indicator?
Its a bog standard 3mm round red LED, you can buy a bag of 'em at your local bits'n'pieces store for a few bucks. If you're anywhere near NW Sydney I can give you a handful of 'em.
But you could always go for a different colour if you'd like .... just to customise your gear a bit.
48V voltage, its got 6K8 series resistor so that's what, 7 or 8mA current, something like that. Pretty much any LED would do.
substitute
Thanks for the offer I'm on the other side of the world though. I was asking about the value because I have two channels of ward becks racked up and ready go, minus the one lost LED, I was hoping to match the brightness of the one thats already installed. I suppose I should just buy a few and if it seems like a problem I'll replace both.
chrisp
Post by chrisp »
Brightness is a mostly question of current and colour. Any standard (as distinct from superbright) red 3mm LED is likely to within the right sort of brightness, so you shouldn't need to sweat this too much.
Sticking with red? Good idea - red light is far better at helping you retain night vision (or venue lighting vision).
