GEQ500 kit BUILD THREAD
Re: GEQ500 kit BUILD THREAD
voxroom wrote:
Sat Oct 11, 2025 10:36 pm
Thank you for the fantastic kit. I really enjoyed building it.
For the most part, everything works perfectly. However, I made a small mistake with a solder joint on the R5-R7-Transistor. Before I risk damaging the board by attempting to desolder it, I wanted to ask: Is this connection point meant to be bridged, or do I need to remove the excess solder?
Thank you for your assistance.
Best regards,
Juerg
Sorry missed this post. Yes those 3 pads are linked by track.
The pads are separate so if soldered correctly there will be a gap but they will all be linked when tested with ohmmeter.
