500 Tester Dual and Single Build Thread
500 Tester Dual and single Build Thread
Dual 500 Tester build map at link below
http://jlmaudio.com/builds/maps/500Dual_Map.html
Single 500 Tester build map at link below
http://jlmaudio.com/builds/maps/500Single_Map.html
10-pin IDC headers are for linking multiple single or dual testers so only one power supply is needed
pin1,2 0v
pin 3,4 link pin 6 of edge connector
pin 5,6 +16v
pin 7,8 -16v
pin 9,10 +48v
14-pin IDC headers on the dual tester. The first 12 pins are half of Tascam DB25 pinout.
So 2 dual testers and be used to fit 500 modules into mixing console etc and easily ribbon cable out to D25 patchbays
Since all in and outs and power are on the 10 pin and 14 pin IDC connectors the XLRs and XLR front panel can be left off making the depth shorter for mounting inside non 500 consoles
pin 1 0v
pin 2 -in left channel
pin 3 +in left channel
pin4 0v
pin 5 -out left channel
pin 6 +out left channel
pin 7 0v
pin 8 -in right channel
pin 9 +in right channel
pin 10 0v
pin 11 -out right channel
pin 12 +out right channel
pin 13.14 0v not normally used
Kifore
Re: 500 Tester Dual and Single Build Thread
Post by Kifore »
Thank you for the links, I will order soon 500 Tester Dual Build. Can you deliver to Europe? All September I will by at my parents Munich home
Kifore wrote:
Mon Sep 07, 2020 3:00 am
OK cool. Yes we send several parcels every day to Europe :-)
slb1959
Post by slb1959 »
Hi Joe.
Received and tested with power. :P
The idc 10 pins is a power connector for other pcb´s?
The idc 14 pins is for input/output connections?
Can i have the diagram of that?
Thanks, Luís
slb1959 wrote:
Wed Nov 29, 2023 9:15 pm
Hi Joe.
Thanks, Luís
HI Luis
Added the info to first post above.
slb1959
Post by slb1959 »
Thanks Joe.
I sent to you one answer to your email.
slb1959 wrote:
Sun Dec 03, 2023 4:25 am
Thanks Joe.
I haven't seen your email?
slb1959
Post by slb1959 »
Nops.... :P
Invoice for the pcb?
Information about the StereoBus pcb? :P
Luís Neves
