Another Animal
Another Animal
Here's a BA i've built for a friend, 99v 1:4 JLM input transformer.
Great pre's, highly recommended.
BL
[/img]
BL
[/img]
I looked through the Hammond site and saw the case. I also saw that they had some extruded aluminum cases that are closer to what I want to do, something like 6"x8"x2". Those are available for $25, not really cheap but I don't plan on doing too much gear (just, you know, a mixer, some eqs, a couple of compressors, a few routing boxes, maybe some a-d-a converters, a lamborghini...), it's still cheaper than buying stuff pre-made off-the-shelf. IIRC my current Baby Animal build uses one of their plastic cases. One thing that's cool about the extruded aluminum is they also have plastic faceplates, so you can try out a few designs before committing to metal, or if you don't have the tools you still get a metal chassis with plastic endcaps that are easier to work with. Anyways, I really like the look of both of these builds and the extruded aluminum adds a nice utilitarian touch (like something you'd find in the back of a minimog). I was thinking these could also look nice mounted in the same kind of boxes that Radial uses (too bad those aren't available for DIY).
Yes what format would you like the engraving file in?How smokin does that look! Don't happen to have the files for the engraving handy?
Yes it is the same Red led switch used in the HAL project prototype box.I do like the push button switch on Joe's - is that switch illuminating, Joe?
NICE!
did you engrave that in-house joe? i seem to remember matt saying something about you getting a milling machine... CNC?
engraving does look very sweet - often looks better than screen printing, in my opinion...
BTW are you still going to do the the half-rack cases? that would be very nice...
haima
haima
