kante1603 wrote:
G-Sun wrote:Hi!
My meter-light died.
How may I replace it?
Hello G-sun,
the squared and the round part can be detached.Take care when doing that,gently tear them apart.No brutal force please,or you might damage the meter or bend the needle.
Then gently tear apart the white inlay.
After that you can reach the led.Take care while unsoldering and soldering a new one in,also watch polarity.
Have attached a pic,hope that helps.
Best regards,
Thanks Udo
Do just as Udo said :-)
G-Sun
Post by G-Sun »
kante1603 wrote:
G-Sun wrote:Hi!
Hello G-sun,
Thanks a lot Udo!
Tried to use my LA500 today, but turns out it's more than the light.
Seems like meter is moving correct GR/Level, but it's not compressing and the Gain-pot is not doing anything.
Any pointers to the cause of the problem?
www.g-sun.no/en/
G-Sun wrote:
kante1603 wrote:
G-Sun wrote:Hi!
Hello G-sun,
Thanks a lot Udo!
Email me some clear in focus photos of your build so I can check it over. And answer all of the below questions.
Does the meter light? If NO link over the outside 2 terminals on the meter with a piece of wire to bypass the led and check if the comp is now working except for light not going. (If the led is blown the comp will never come out of bypass mode otherwise.)
Does threshold turn the level down ? Does GR meter show reduction?
Does makeup turn the level up?
G-Sun
Post by G-Sun »
Joe Malone wrote: Email me some clear in focus photos of your build so I can check it over. And answer all of the below questions.
The unit has worked perfect for some 3 years.
Please tell me if you need the pictures after reading this post.
There is no light.
No, there is no audio GR, but the meters show GR.
No
Your explanation that the unit does not come out of bypass-state, caused by the VU-led, makes very much sense.
Meters is showing GR, and VU-out is reacting to GR and MakupGain.
If you don't tell me other-wise, I'll just test with bypassing led, and then change led.
What's the specs for a replacement led?
Very helpful answer :)
www.g-sun.no/en/
Yes first try a wire across the outside terminals of the meter to bypass the led and see if the comp works without led just to check all the wiring is ok.
Led is white clear 5mm about 800 to 1000mcd. We have the LED as spare part on our website if you are trying to match other LA500 meter lights exactly. Open the meter as Udo showed to check led hasn't broken off one of the mounting posts if comp has been working so long. If still soldered in place replace led. New led must go in same way around Anode & Cathode and face the top of the meter. In LA500 you can unclip back of meter without removing wires or meter from the metal frame.
G-Sun
Post by G-Sun »
Joe Malone wrote: Yes first try a wire across the outside terminals of the meter to bypass the led and see if the comp works without led just to check all the wiring is ok.
Thanks a will!
Was hitting the replacement led in your shop until 20aud for shipping :)
I'll have a look another place
www.g-sun.no/en/
G-Sun
Post by G-Sun »
Now, look here:
Seems like we've found the course.
Remember when soldering that this spot seemed a little weak :)
Fixed. Working perfect again. Thank you!
www.g-sun.no/en/
kante1603
Post by kante1603 »
G-Sun wrote:Now, look here
Looks like an LA500A to me,not LA500.
Wrong thread......?
Cool great to hear it was a simple solder joint to fix :-)
This is a LA500A not LA500 so I will move it over to the LA500A build thread
studiomollan
Post by studiomollan »
If you were to try and fit an original T4B module in here, where would it go? I just replaced a drip t4b for a kenetek in a diy LA2a and it made such a huge difference. Im not saying the la500 sounds bat the way it is, i love mine, but would be fun to hear the difference.
Emil
studiomollan wrote:Hi,
Emil
The LA500 cannot run a luminescent cell as they need 40vac to 200vac to light. So T4B will never work in LA500.
studiomollan
Ok. then i know. Thanks joe!
Alexcook
Broken LA500
Post by Alexcook »
Hi, this is my first post so excuse my incompetence.
I’ve inherited a dropped LA500, the original one without the push pots. Its working as far as it switches on and lights up.
When i engage the compression the signal drops to almost inaudible, and a load of low end hum comes in. The signal as far as i can here is compressing however and the meter is just about moving
I have a video but it wont let me attach it
What could this be? Any help greatly appreciated as i’d love to get into using this thing on my projects
Alex
Re: Broken LA500
Alexcook wrote:
Wed Oct 25, 2023 7:49 pm
Alex
I have moved this post to the LA500 build thread.
Do the LA500/BIO500 test below. And let me know if the BIO500/LA500 pcb is working correctly or not. Attached well lit in focus photos of the assembled LA500 and tops of the pcb with JLM99v removed
Test BIO500/LA500 main pcb by itself by unplugging BIO500/LA500 main pcb ribbon cable from LA500SC pcb and fitting two cut-off component leg loops as shown below.
You can plug the relay green wire loop in and out to switch between bypass and BIO500 audio path to check the audio level is correct.
harrissound
Post by harrissound »
Hi there, I have a LA500a on my bench, it was initially brought to me by someone who said the GR meter didnt work althought he said the unit itself works fine audio wise, after following the calibration procedure by applying 1k sine wave @ 1.23ACrms from my sig gen to the input I measure unity on the output, this increases somewhat when the unit is powered up, however when trying to zero the Vu meter the furthest it will go is to -2dB before the trimmer maxes out, zeroing the GR works fine though, I can confirm c18 is the correct value, I have also gone through all the components with my dmm to check they are correct, this includes the schottky diode strings.. I cant seem to figure it out..to reach 0db by increasing input signal im hitting around 1.7vac on the output, I sucked out the trimmer aswell to confirm its correct (1K)..I'm powering the unit up on the bench using my bench power supplies with the correct bipolar voltage on the correct pins (-16v 0 +16v)...another thing I've noticed is that (I might be wrong about this) -6db should cut the output voltage by half? while maxing out the threshold pot the most it will reduce the output voltage is down to around 800mV...I have also tried replacing the opamps one at a time with a tl072 to check there was no issues with those...I've reflowed the pcbs & scrubbed with iso and checked under my microscope for any solder bridges or broken traces...Any help would be really appreciated! Link Below to some pics of the pcbs themselves...
https://drive.google.com/drive/folders/ ... sp=sharing
