These are a couple of BA1's we have made in the Hammond cases.
I like these cases but they are not cheap and the screws strip easy and come loose so we change them to longer different type ones to keep the box together tightly.
Wow, well i feel like i've walked into a Neve factory with a B%!^@*&. How smokin does that look! Don't happen to have the files for the engraving handy?
I looked through the Hammond site and saw the case. I also saw that they had some extruded aluminum cases that are closer to what I want to do, something like 6"x8"x2". Those are available for $25, not really cheap but I don't plan on doing too much gear (just, you know, a mixer, some eqs, a couple of compressors, a few routing boxes, maybe some a-d-a converters, a lamborghini...), it's still cheaper than buying stuff pre-made off-the-shelf. IIRC my current Baby Animal build uses one of their plastic cases. One thing that's cool about the extruded aluminum is they also have plastic faceplates, so you can try out a few designs before committing to metal, or if you don't have the tools you still get a metal chassis with plastic endcaps that are easier to work with. Anyways, I really like the look of both of these builds and the extruded aluminum adds a nice utilitarian touch (like something you'd find in the back of a minimog). I was thinking these could also look nice mounted in the same kind of boxes that Radial uses (too bad those aren't available for DIY).
