POWER PLANT BUILD THREAD
Re: POWER PLANT BUILD THREAD
I have a power plant here that was blowing fuses (unloaded so I know it's the power plant) I replaced the 110/220 switch and it stopped blowing fuses but I couldn't adjust the regulators for 24 and 48V's They only go up to 17VDC and 35VDC respectively. I tried replacing the regulators to see if they were the problem but no change. And the power transformer is getting very hot.
Any ideas what's going on here?
This can't be right. I have 51VAC, 54VAC, 56VAC, 62VAC on the power transformer secondaries. ??? Maybe I hard wired the pirmaries wrong. Okay, it's a DPDT slide switch so I hardwired the side that says 110V. I don't get it. . .
The 115v / 230v switch overlay shows the correct way to fit the switch which should be fitted but if you do not fit the switch since it is a slide switch that shows the voltage when slide the opposite way you would have to jumper the opposite side to the voltage written on the pcb. But I cannot see how either way you could get that winding voltage unless something is built wrong. Remove the 2 silicon tubes and send me some top and bottom photos of your kit build so I can check it over.
Thanks Joe,
Here's some pics. This was a successful build, calibrated correctly and powering four Neve 1290 cards for about 6 months. Then one day I powered it on and the fuse blew.
So I suspected that slide switch.
So, if I get you right, the correct pads to jumper for 115V would actually be on the 230V side, according to the pcb. Interesting. So I was getting the voltages on the secondaries mentioned in the earlier post while accidentally connecting the primaries for 230V. Now connecting the primaries correctly I'm back to blowing fuses again upon power up.
Sounds like a dead short on one primary winding. Remove power and remove the 2 110v jumper wires and check the ohms on each 115v primary winding which should be about 80ohms each from memory. Check there is no solder short under the pcb at the high volts end. let me know what you find.Jonk wrote: ↑Tue Sep 07, 2021 2:29 amThanks Joe,
If the ac volts on the secondary was actually the volts you mention the 1000uF caps would all have blown their tops.
Okay,
back with some ohm readings. Sounds like you're right (I think?) One primary reads 16ohm. The other is 91ohm.
So, what would you expect to need to be replaced besides the power transformer? Caps as well? Not seeing them puffing out though.
HI Jonk
It should only need a new transformer as the caps look fine. Email me to so i can quote price for one with shipping for you.
Hi! Just received (and built) a Power Plant 2. Super easy assembly, good instructions, and after trimming the regulators I'm getting a beautiful steady spot on 24/48v on the outputs. Beautiful.
I plan to install this into an external enclosure to lower risk of noise/hum in whatever gear I end up powering up with this. I bought a few Hammond and other boxes that I think will fit, so I have some options for which I like the most. Once I am completely finished I will post pics from the full build, if that's a useful thing to do.
My question: I have never used 4-pin XLRs before, which is what I plan to use for the power out. Obviously I can just wire it up however so it works, but I am curious if there are any best practices for this type of power cable wiring? I can't seem to find any resources online for this. Here's what I'm thinking.
Pin 1: 0v
Pin 2: 24v
Pin 3: 48v
Pin 4: Chassis ground
G: Also chassis ground (bridged to pin 4)
Does this make sense? Any problems here? Should I not hook up chassis ground at all? Should I not bridge the shield/sleeve of the connector to a pin, like I was thinking with pin 4/G?
Would love some feedback.
Thanks again!
Pin 1: 0v
Pin 2: 24v
Pin 3: 48v
Thanks again!
I don’t know of any standards for 4 pin XLR’s but usually always pin 1 chassis / ground like audio XLR. A lot of female 3,4,5 XLR pin 1 are raised to make contact first.claussoegaard wrote: ↑Mon Apr 17, 2023 5:33 pmHi! Just received (and built) a Power Plant 2. Super easy assembly, good instructions, and after trimming the regulators I'm getting a beautiful steady spot on 24/48v on the outputs. Beautiful.
Pin 1: 0v
Pin 2: 24v
Pin 3: 48v
Thanks again!
API 5 pin power
Pin 1 chassis
Pin 2 GND 0v
Pin 3 +16v
Pin 4 -16v
Pin 5 48v
JLM TMP8 48v power
Pin 1 0v
Pin 5 48v
Awesome, thanks Joe.
Based on that I think I will do:
Pin 1: Chassis
Pin 2: 0v
Pin 3: 24v
Pin 4: 48v
Pin 1: Chassis
Pin 2: 0v
Pin 3: 24v
Pin 4: 48v
Seems like a plan.claussoegaard wrote: ↑Mon Apr 17, 2023 6:36 pmAwesome, thanks Joe.
Pin 1: Chassis
Pin 2: 0v
Pin 3: 24v
Pin 4: 48v
I always use 5 pin for power if multiple rails so I have power pins in the same place encase a power supply is swapped. A +V being a few volts higher or lower is usually not a problem but -v and +v swapping is bad
My powerplant wiring so it matches my 500 rack power supplies.
Pin 1: Chassis
Pin 2: 0v
Pin 3: +V
Pin 4: -V (not used)
Pin 5: +48v
