ylinjohto
Post by ylinjohto »
[/quote]
Check the BA is fully working with NE5532A and input reg voltage is set to +30 to +36vdc on +V of the opamp sockets. If so you should be able to remove the NE5532A and fit 6 sockets and plug in the discrete opamp. Remember the discrete opamp is only driving the +out so link on dip socket is needed to put -out to 0v so quasi balanced out works.[/quote]
Opamp voltage is 24,1 and I guess that is ok because the Soun Skulptor sk99 is 24v op amp. I just need to clarify what exactly needs to be connected? 0V opamp socket to -output of the line output? Did I understood this correctly?
Thanks![/quote]
If sk99 is +/-24v you want the reg linked over so you have +48v on +V pin as the BA uses this 48v as +/-24v but 0v is referenced to -24v.
ylinjohto
Post by ylinjohto »
Hi, Thank you for information!
I was wondering what is the output impedance of the unit. With JLM14 input tranfo and NE5532A op amp. Does DOA change output impedance?
ylinjohto wrote:Hi, Thank you for information!
Balanced output impedance with NE5532A or discrete opamp no output transformer using +out and -out is 102ohm if using 51R or 66ohm if using 33R.
Vernois76
Post by Vernois76 »
Hey Joe, just got my BA kits in today. Just a quick question; on this version 2 you’ve added a trim adjustment for the opamp. Is there a setup necessary for standard 48v supply and 24v opamp?
Thanks for your time!
Gavin
Vernois76 wrote:
Mon Jun 08, 2020 3:00 pm
Gavin
HI Gavin
For +/-24v opamps you can leave off the BD681 and still link E - C or just wind the trimpot to full. Either works fine. See the Ver 2 schematic under the photo of the new balck Ver 2 pcb for detail.
papiblu
Post by papiblu »
Dear Joe,
cause Im a lazy bastard , I leave this unfinished Baby Animal in my garage for a couple of years.
It doesnt sound and I have no clue why.
Im sending you some photos, and maybe you find the problem
IM feeding it with the 48v of one of my powerplants that works perfect with other Pres.
Please let me know if you need some more photos
Thanks in advance.
All the best
p.
papiblu
Post by papiblu »
More photos
Cheers!
papiblu wrote:
Thu Feb 04, 2021 9:21 pm
Dear Joe,
Thanks in advance.
All the best
p.
With link over BD681, the trimpot shouldn't be fitted. The standard setup on black pcb is trimpot and BD681 for extra smooth reg but since you are using 48v from power plant it will be smooth. Remove trimpot.
Output transformer should be wired to +out and 0v not -out so that may stop any sound from getting out. So move wire from -out to 0v.
If still no sound check voltages at opamp sockets to 0v with no opamp fitted and with opamp fitted and let me know the voltages you get.
MichaelGNunn
Post by MichaelGNunn »
I am putting together a Dual99v, and have a quick question on the transformers. The transformers in the pictures seem to be wired differently than the overlay, I assume I follow the overlay. In other words, should I connect the number on the transformers to the corresponding point on each pcb?
thanks,
MN
MichaelGNunn wrote:
Mon Feb 22, 2021 8:19 am
thanks,
MN
Yes the output transformers has 3 identical winding so can be wired in several correct ways.
Best to always follow the overlay and make sure you fit the wire link to the transformer which several people miss.
MichaelGNunn
Hi Joe, I got everything together on my dual 99V and it sounds great aside from some noise issues! I looked through the forum, and it seems someone else has had this issue. It sounds like some electrical interference or grounding issue. can this be fixed by getting a power conditioner that separates my analog equipment from digital equipment computer, or do I need to open it up?
MN
MichaelGNunn wrote:
Mon Apr 12, 2021 5:27 am
MN
HI Michael
Do you have a sample of the noise you can send me with nothing connected to the input of the mic pre?
MichaelGNunn
Sorry for the delay, here’s a link to a sound sample:
https://soundcloud.app.goo.gl/Qtga4fhyBNJzr2ah7
MichaelGNunn
Post Mon Apr 12, 2021 1:18 am
MichaelGNunn wrote: ↑
MN
HI Michael
I posted a broken link. This one should work! This is with all three knobs turned all the way right
https://soundcloud.app.goo.gl/nN99k1SjcBRZNMuW7
