jrowell wrote:Joe Malone wrote:api wrote:Hi.
To avoid unused op amp section being driven to negative rail connect Pins 6 and 7. Pin 5 must go to 1/2V source for single ended PSU topology. Re:
https://www.maximintegrated.com/en/app- ... vp/id/1957
James Rowell
While I agree with the link in normal precision audio path setups. Not in this case as with TL072 in VU buffer sharing the 1/2v with another input just makes opamp lock up more common at high gain setting. If you want to do this you must down size the 2 x 47k half rail resistors down to 2 x 10k and increase the half rail cap to 100uF to stop large turn on thumps pinning the VU meter to Full Scale and not have lockup problems. This mod uses more current than driving the spare opamp to 0v.
Or easier just do as I said originally as the extra current is tiny in TL072 and noise floor change is minimal and not seen due to the diode bridge feeding the meter.
