ghaudio wrote:Hi Joe, have you had a chance to review the picture? Is there something else I can send to make this easier to resolve?
Do you have +24v between 0v and +V on the dingo?
Do you have -24v between 0v and -V on the dingo?
If you remove the 4 x 99v on the dingos and power up do both VU meters go back to -20dB?
Does the 1k trim measure 1k when fully turned down?
Send me a photo of the two dingo top without opamps fitted
ghaudio
Post by ghaudio »
Finally found a moment to get to testing this out. I discovered that the positive power line into Ch 1 dingo had worked itself loose so there was no connection. I corrected that.
I removed the 4x 99v opamps and didn't see the VU's go back to -20db on power up. Then I encountered a new problem.
Couldn't complete the rest of your test's because I did something to cause the power on the unit to start flickering. All the power connections look to have a good solid connection, the fuse looks good, but now the power and power LED's are flashing on and off at about 1 second intervals. I suspect that I plugged the opamps back in with the power on. With the opamps in, or with the opamps out, the power flickers. Do you suspect I blew something up by plugging those back in while powered up?
Pictures and answers to your questions for the original issue below.
unable to test
unable to test
The VU Meters did not return to -20db
unable to test
PCB's look fine. If power supply is hiccuping one or more of the 4 x 24v 1w zeners will be short circuit.
Replace short circuit zeners and you should be going again.
When going again do the above volts test with opamps fitted.
If the meter never turns down even with no input on VU then there will be a power rail down or opamp dead on LA500sc or solder short under the LA500sc pcb.
RAPHAEL
Post by RAPHAEL »
https://photos.app.goo.gl/IWe87jhtfcYTYDCp2
on the LA500POTv4 the thread doesnt show the 120k resistors being installed. do i not need to uses them?
also on the LA500SCv3 the thread shows a different version of the board. mine has 2x transistors and 2x 1 uF caps where the 2x 10R resistors are also the 1 uF cap just below the leds has been omitted. if i could get a point in the right direction that be great
RAPHAEL wrote:https://photos.app.goo.gl/IWe87jhtfcYTYDCp2
Yes as blue led is not used so 2 x 120k are not fitted but if you have fitted them it is also ok as they are not used.
Due to OPA2604AP opamp being unavailable and our stock running out recently the pcb has a been changed in that corner to use 78L12 +12v and 79L12 -12v reg instead of the 78L05 +5v reg.
Just fit all the parts as shown on the overlay of the PCB so no 10R no 78L05 instead fit 78L12 and 79L12 and 3k3 resistor as shown and it will work fine.
RAPHAEL
Post by RAPHAEL »
Im in the diagnostic and calibration phase of my build and I am getting a 30kHz resonance in channel 1 any suggestions?
RAPHAEL wrote:Im in the diagnostic and calibration phase of my build and I am getting a 30kHz resonance in channel 1 any suggestions?
Please explain more? Do you have a bump in the frequency response at 30khz? Or do you mean you have oscillation at 30khz?
fistman
Post by fistman »
Just getting going on the dingo and saw the note about avoiding using the () and [] components when using your 99v opamps. Wanted to verify that I should NOT place R17, R18, R20, C11, C13. You have those installed in the pictures, and you seem to be using the 99v opamps in those photos as well, so I was a little bit confused. I see there are no components in the dingo kit for the () values, but it seems you installed the components labeled with []. I already soldered the resistors 17,18,20... oops, but could easily just cut them off heh :mrgreen:
Thanks in advance!
fistman wrote:Hi Joe,
Thanks in advance!
It is fine to fit all of those parts as it doesn't make any difference to the working of the dingo with JLM99v. So no need to take them off.
We just build the dingo up universally so they work with JLM99v and normal DIP8 opamps which is why we fit all the extra parts.
fistman
Post by fistman »
Understood. May as well solder in the other caps too then, as they're already placed. Thanks for the quick reply!
fistman
Post by fistman »
Hey again Joe,
Got to the calibration stage - the first side went well. Then got to the second side and had 1.67v output... after some investigation, I noticed I somehow missed installing a 100k resistor on the dingo :roll: That side is reading around 1.25v output now with 1.23v input (I assume this is close enough, as the other output reads 1.21v ?). Mostly just wondering if I could've damaged anything by having it up and running for a couple hours or so without the 100k resistor installed (located between the two op amps), but also if the voltage discrepancies are any problem.
I've done some mic pre kits, but still relatively green when it comes to calibrations etc. so after realizing I wasn't sure how to figure out my reference levels for my converters, I tested and trimmed all my output channels individually to get as close to 1.228v as possible. Hopefully my multimeter is calibrated well heh.
Anyway, I'm trudging forward with the calibration on the side I fixed. Just looking for a little reassurance I haven't strayed too far from the path.
fistman wrote:Hey again Joe,
Leaving the 100k out won't damage anything but would put the cal out between the 2 channels if calibrated that way.
The output level of 1.23v isn't very critical so 1.21v to 1.25v etc is fine. But if you can get the same value for both channels is good.
You can use the makeup pot to trim the level when a bit calibrating.
