Hello, have the following problem: at high frequencies I have full rash, at low frequencies only very low rash on the VU-meter. At the same outputlevel. Is that so normal? I have 500 uA VU-meters...
Alex
Alex
What meters are you using?
Do they have diode bridge in the meter?
Have you fitted the diode bridge on the VU2 pcb?
Photos would help check the pcb build and wiring.
No not normal.acidfarmer wrote:Hello, have the following problem: at high frequencies I have full rash, at low frequencies only very low rash on the VU-meter. At the same outputlevel. Is that so normal? I have 500 uA VU-meters...
Alex
I have this VU-meters:
https://flashstar.en.taiwantrade.com/pr ... 92601.html
I have fitted the diode bridge.
Are you driving balanced input signal in ?
That should work fine. Need some photos of the VU2 pcb top and bottom and wiring as it is at the moment.acidfarmer wrote:I have this VU-meters:
Yes, i drive it with balanced input signal. Here the Photos:Joe Malone wrote:
As your description sounds like when transformer output is open one leg so only high frequency bleed comes out.
So the balanced audio output this is wired across sounds like full audio range when you listen music?acidfarmer wrote:Yes, i drive it with balanced input signal. Here the Photos:Joe Malone wrote:
Yes, the Audiosignal is full range. I have testet the VU-meter with another bufferboard from China at the same audio ports. With the china bufferboard i don´t have the frequency problem.Joe Malone wrote:
Do the blue caps have 105 or 104 written on them?
Does the china board have balanced in?
What frequency does it roughly roll off at?acidfarmer wrote:Yes, the Audiosignal is full range. I have testet the VU-meter with another bufferboard from China at the same audio ports. With the china bufferboard i don´t have the frequency problem.Joe Malone wrote:
The frequency goes from 10hz to 22khz at the delta 1072 output. The vu-meter shows at 100 hz only -15db, at 10khz it indicates + 4db for example. When i use a fullrange signal (music), displays the meter accordingly. So at low frequencies, low levels, high frequencies come at a correspondingly higher level. I have tested the JLM board unbalanced...it´s the same result.Joe Malone wrote:
The cinaboard have only unbalanced input.
The blue caps have 105...
If you connect the VU buffer across the balanced out of D/A etc does it still have the same problem?
Where did you connect the unbalanced board to as this is transformer floating out by the looks? So should not have worked on the output?
OK makes no sense at all then.acidfarmer wrote:The frequency goes from 10hz to 22khz at the delta 1072 output. The vu-meter shows at 100 hz only -15db, at 10khz it indicates + 4db for example. When i use a fullrange signal (music), displays the meter accordingly. So at low frequencies, low levels, high frequencies come at a correspondingly higher level. I have tested the JLM board unbalanced...it´s the same result.Joe Malone wrote:
I just tested it directly on the audio interface. Same result in behavior ...with balanced and unbalanced in. Strange...Joe Malone wrote:
Do both left and right do exactly the same thing?acidfarmer wrote:I just tested it directly on the audio interface. Same result in behavior ...with balanced and unbalanced in. Strange...Joe Malone wrote:
Yes...Joe Malone wrote: Do both left and right do exactly the same thing?
I found the mistake ... that's almost embarrassing for me ...
The construction manual states:
input cable red = +
yellow = -
black = ground
But the supplied plugs have the assignment red = - and yellow = +, if the plugs are mounted as on the pictures.
My mistake was to orient myself to the cable colors, instead of making sure that the connector assignment is the right way around.
Big Thanks for your support Joe!
Shame on me...
Alex
input cable red = +
yellow = -
black = ground
Shame on me...
Alex
Sorry for the stuff up. Great to hear you worked it out. Strange the wrong colour code. Are the 3 pin cables in the kit short wire (150mm to 200mm) or ones with locks and 300mm wire? Photo would be great as the colour code shouldn't be changing if the right cables are being packed in the kit. Thanks for spotting the problem I will have to get this worked out ASAP as I don't want colour changes causing confusion.
HI Alexacidfarmer wrote:I found the mistake ... that's almost embarrassing for me ...
input cable red = +
yellow = -
black = ground
Shame on me...
Alex
