Go Between..
Vib
Go Between..
Post by Vib »
Hi there!
What measurments to do before power up the Go Between + DI ?
Just make sure the 48v is wired to the +48v and the 0v to the 0v. The 48v led should light showing everything is ok when the 48v switch is turned on and you should be able to measure at the input XLR without a mic plugged in 48v at pin 2 and pin 3 measured from any ground or 0v point. Once that all tests ok turn off and remove the 2 jumpers from the DI socket on the Go between and plug in the DI ribbon cable and see if it all works when powered up again.
