I just purchased the SEW 315 VU meters to go along with the VU2 buffer kits. Do these meters have internal rectifiers?
srgny wrote:I just purchased the SEW 315 VU meters to go along with the VU2 buffer kits. Do these meters have internal rectifiers?
NO all the SEW meters are DC. So fit all the diodes to the VU2 pcb to make them work properly
My kits have arrived. The meters (SEW ST-315) come with no mounting or hook-up instructions. There are 4 solder lugs on the back. I assume 2 are meter inputs and 2 are for the led. Which is which? Which is + and which is -?
srgny wrote:My kits have arrived. The meters (SEW ST-315) come with no mounting or hook-up instructions. There are 4 solder lugs on the back. I assume 2 are meter inputs and 2 are for the led. Which is which? Which is + and which is -?
The inside pair of terminals are the DC meter and outside terminals are the led. There should be a plastic molded + in the white plastic above the meter terminal this is + and the led + terminal is on the same side as well.
Looking from the back of the meter the terminals are +LED +METER -METER -LED for all SEW Meters
Thanks for your quick reply. Another question: What voltage does the yellow LED in the meter use. Is there a place on the PCB board to wire to the meter LED?
Sorry for the dumb questions.
srgny wrote:Thanks for your quick reply. Another question: What voltage does the yellow LED in the meter use. Is there a place on the PCB board to wire to the meter LED?
Yellow led is 12vdc and wires to +L and -L. If running on 12vdc power make RLamp 10R.
From first page of this thread. See pcb on that page for pinout of 4 pin headers for this
OUTPUTS
Sorry, I screwed this up. I have the VU Buffer & Peak led kits. Same questions.
srgny wrote:Sorry, I screwed this up. I have the VU Buffer & Peak led kits. Same questions.
LED just wires directly across the 12VDC power input
No resistor needed?
srgny wrote:No resistor needed?
No resistor needed if you are using 12vdc. If volts is higher then you will need to add resistor.
This is Jason again, the last dude to post something on the AC/DC thread. I don't have any of my stuff on SM. But if I do post it in the future, I'll be sure to mention your company. Great service and products your offer. Very much akin to John Hardy's company and products!
I have another quick question, this time concerning the stereo version of the vu buffer. Is there a way to set up peak indicators like on the mono buffers?
Sincerely,
Jason
Sincerely,
Jason
xstnhealer wrote:Hello Joe,
Sincerely,
Jason
HI Jason Thanks for the kind words
Yeah, I thought not, but I was hoping that it might be a simple mod, since it looks like a similar circuit. I'll keep my eyes peeled for the daughter board option.
Kind words earned. No thanks necessary!
Sincerely,
Jason
Sincerely,
Jason
