PM2K EQ MOD...HYBRID OPAMP
Ok i have eq mods all ready to install, well one question... the caps on the low mid, 2.2 & 3.3, theres no indication on the polarity. I also successfully built 2 of the Hybrid opamps. I first run in class A and wanted to try AB...when i first installed with class A the LED worked and everything sounded good but after i removed and soldered the jumpers on each, nether one of the opamps LEDs would come on but both still worked. Any thoughts? thanks
The Hybrid kit red led lights when in Class A and should be off in Class A/B.
Re: PM2K EQ MOD...HYBRID OPAMP
The 2.2uF and 3.3uF caps in the PM2000 EQ kits are Non Polar types so can go in either way around.audioguy wrote:Ok i have eq mods all ready to install, well one question... the caps on the low mid, 2.2 & 3.3, theres no indication on the polarity. I also successfully built 2 of the Hybrid opamps. I first run in class A and wanted to try AB...when i first installed with class A the LED worked and everything sounded good but after i removed and soldered the jumpers on each, nether one of the opamps LEDs would come on but both still worked. Any thoughts? thanks
