Postby Joe Malone » Tue Oct 15, 2013 2:08 pm
VU Buffer and peak led schematic here
Assembly is the same as the original VU Buffer kit here
Disabling the rectifier for meter with internal rectifiers is also the same.
To Setup VU Buffer and Peak LED pcb.
1. Connect dc power you are using. VU buffer and peak led can run on +12 to +36vdc @ 30mA so main current draw will usually be the VU meter light.
2. Send 1kHz tone in at the reference level you want for the VU meter like +4dBM for example.
3. Adjust Trimpot marked VU for correct 0VU level for your system.
4. Send 1kHz tone in at the reference level you want for the Peak LED meter like +18dBM for example.
5. Then adjust trimpot marked LED until the LED just lights.
Note to set high peak levels than +18dBM or +18dBu a power rail of more than +12vdc will be needed.
permeke
Postby permeke » Wed Dec 25, 2013 10:00 am
just wondering if there is a mod on this pcb to alter the limit behaviour of the meter used.
let me explain, I have some vintage meters that I want to use , but somehow when they are at full scale , they got stuck at the very end. think it's a mechanical thing.
If I could adjust the response so that they just don't reach the very end, I would be a happy man.
Postby Joe Malone » Thu Dec 26, 2013 8:08 am
permeke wrote:just wondering if there is a mod on this pcb to alter the limit behaviour of the meter used.
Analog meters overshoot so there is no way to limit them at 100% full scale.
You just need to fix the end stop so the needle doesn't stick to it. Or bend the needle so it doesn't touch the scale or front glass.
You can usually add a small bit of plastic tube to the metal end stop so it doesn't stick to the needle.
jpertusi
Postby jpertusi » Thu Apr 17, 2014 10:47 am
Howdy,
I just got my pair of JLM Large Meters and 2 of the buffer kits with peak LEDs.
I've got a few questions:
Do the lamps need their own power or can they be run from the voltage coming in to the pcb?
I assume the PCB is not meant to be directly mounted to the meter housing?
Is the red led meant to be inside the meter housing so the entire meter face lights red when it peaks?
Any help is appreciated,
-JP
Postby Joe Malone » Thu Apr 17, 2014 11:46 am
jpertusi wrote:Howdy,
Yes using the 12vdc to 24vdc can be used to run the buffer and lamps. Most meter have 12v or 6v lamps so running them in series or parellel will usually get them to match the voltage the buffer is running on.
Often the PCB is mounted directly to the meter terminals as you will see in the original VU buffer build thread with the photos. But new VU buffer peak led kit also has one mounting hole so PCB can be mounted to case etc.
Usually it is just mounted on the front panel outside the meter
or
Some guys drill a small 3mm hole in the top right corner of the meter itself but you have to be very careful and know what you are doing. So not a good idea for a beginner
-JP[/quote]
stitchy
Postby stitchy » Fri Jul 04, 2014 11:24 am
Hello!
I have a Buffer Peak kit I built and Im not sure were my issue is.
Attached are pics of the VU and circuit.
It is vintage and I believe a real VU. It is attached from output of your buffer amp.
I measured audio AC at your buffer input.
DC power rail is measured at 10.76VDC at Buffer amps DC input.
No VU movement tho.
My question to make it easy to see if I put the PCB together incorrectly or I have a bum VU: Would the over/clip LED still light if I sent an excessive input signal?
Is there an easy way to test if the VU is not working?
Postby Joe Malone » Sun Jul 06, 2014 9:07 am
stitchy wrote:Hello!
No VU movement tho.
(From the email I sent you.)If it is a real VU meter does it run directly wired across a audio signal with no buffer?
This will prove if the meter is working and/or has a internal rectifier. If it has no rectifier the needle will wiggle around the minimum settings of the meter.
The peak working depends on its trim pot setting and the power rail you are running the VU buffer on ? So if you have haven't touch the trim pot from when the kit was built the LED will light with high levels once you have set the VU trim to show +4dBM = 0VU.
What are the 3 input wires to the buffer wired too? Yellow? Red? Black?
stitchy
Postby stitchy » Mon Jul 07, 2014 4:18 am
No VU movement tho.
Hi Joe!
Thanks for the replies.
The VU, with direct input from audio, works and does much more than minimal, so I think it both works and
has a rectifier.
The 3 input wires are yellow- shield, Black - low audio, red - hi audio....
EDIT I think I got it! bad solder point, VU now fed by buffer amp.
THANKS Joe!!
-s
Postby Joe Malone » Mon Jul 07, 2014 7:36 am
Cool good to hear you got it going :-)
costes
Postby costes » Thu Feb 12, 2015 9:29 pm
Could anyone confirm the peak led voltage coming from the pcb is 1,3v?
Thank you very much :)
Postby Joe Malone » Sat Feb 14, 2015 1:17 pm
costes wrote:Hi,
Peak led on voltage coming from the PCB with no led attached is the voltage you are running the VU buffer / Peak LED kit on but with a series 47k resistor to limit current to the 2v red high brightness led supplied. So with LED attached and permanently on you will get a reading of 1.6 to 2.2v across the LED.
JeremyStarseed
Postby JeremyStarseed » Thu Jul 02, 2015 9:14 pm
Hi, I'm wondering if a 500 µA DC = FS (DB meter) constitutes a "real VU meter" and if it can be used with the buffer kit? Would it need any additional resistors or modification?
Bought a few kits...and so I'm wondering if another pair of 1 mA DC meters would suit the buffer to display standard VU action? If so, this circuit is a winner. If not...many gain reduction gauges use 1 mA DC...so, no problem. If yes...would swapping polarity allow me to rotate one of the meters? They're square and would look really funky with symmetric movement.
Postby Joe Malone » Mon Jul 06, 2015 10:12 am
JeremyStarseed wrote:Hi, I'm wondering if a 500 µA DC = FS (DB meter) constitutes a "real VU meter" and if it can be used with the buffer kit? Would it need any additional resistors or modification?
HI Jeremy Both 500uA and 1mA DC meters will work with the VU buffer kits perfectly without any series resistor or changes needed.
You usually cannot rotate a meter but if the needle position screw allows you to set the meter to sit fully at the other end of the scale then yes swapping polarity will make the needle move backwards.
jensenmann
Postby jensenmann » Mon Apr 11, 2016 3:42 am
I need to make my VU buffers switchable between 0VU=+4dBu and 0VU=+14dBu, while the peak LED is supposed to always monitor the same level (+18dBu). Do you see an easier solution than lifting one leg of VR1 and VR2 and switching resistors in line/out of line with these?
thanks
Jens
Jens
Postby Joe Malone » Mon Apr 11, 2016 7:51 am
jensenmann wrote:Hi Joe
thanks
Jens
HI Jens Cal the VU for 0VU = +4dBu and set peak led and switch a resistor in series with the meter for the 0VU = +14dBu. This resistor value varies between between meter types of course.
If the range is to wide then your solution is the only way. But 10dB should work fine with the series resistor.
