yep - all good re; pin#1's...
Power is on, and staying on, Mac LINK LED works when in 'link' mode, and and Dingo's are measuring spot on +/- 24v at VS+/- . The IDC Header on the left dingo cable that I re-terminated was the only thing that looked a little sus, even though it tested ok with a multi-meter, I've replaced the plug anyway. The reason I blew the zeners before I can only put down to either this plug, or a faulty connection between my chair and my fingers....
However - (
http://www.mixosmosis.com/POT_VU_wiring.html
Can you just confirm for me that what you see is correct...?? I've triple checked with your hand drawn schem for MAC general wiring - I believe I've got it right, but...
I haven't yet calibrated the unit, but when in GR mode, both VU needles go hard left, and pop back up to -20dB when in bypass mode. But like I said, no LED's are working on the VU's...
Also - do these VU meters have internal rectification...?? (re; wiring D5 to D8)
Thanks for your patience & ongoing support, I'm enjoying the experience !! Nathan
