The unbalanced out feeds a 5k T pad rotary switch. I would like to have as much headroom as possible on the output. A +21dBu clip point at the unbalanced input would be ideal. I also changed R25 to 5k for correct termination of the pad.Joe Malone wrote: But I am not sure what the unbalanced device is that the dingo is connected too?
But if it is passive then that is usually fine.
Re: DINGO PCB and kit Now Available
Paul Gold
Salt Mastering
Salt Mastering
For +/-24v opampsGold wrote:The unbalanced out feeds a 5k T pad rotary switch. I would like to have as much headroom as possible on the output. A +21dBu clip point at the unbalanced input would be ideal. I also changed R25 to 5k for correct termination of the pad.Joe Malone wrote: But I am not sure what the unbalanced device is that the dingo is connected too?
Clip points in your setup
bal in +20.5dBu / unbal out +20.5dbu / unbal in +15.5dBu / bal out +26.5dBu
Clip points with R4 and R6 changed to 10k and 17db GAIN from output amp and balancing
bal in +26.5dBu / unbal out +20.5dbu / unbal in +9.5dBu / bal out +26.5dBu
I would like to build a Pultec'ish EQ with the DINGO, using my own filter circuit and have some questions:
For debalancing / input impedance matching I would like to use the Hybrid or 99V opamp. Does the first opamp contribute noticably to the sound as it has gain = 1?
For gain makeup, is it possible to use an API 2520 with the JLM111DC output transformer for balancing?
Any other suggestions for maximum sonic bliss?
thanks and best regards, Marten
Only slightlymartthie_08 wrote:I would like to build a Pultec'ish EQ with the DINGO, using my own filter circuit and have some questions:
Yes but best to use our JLM25HV version of the 2520 so you can run +/-24v rails for best headroom.For gain makeup, is it possible to use an API 2520 with the JLM111DC output transformer for balancing?
For fat sounding EQ and best headroom use +/-24v rails with JLM25HV or Hybrid for input and JLM99v with JLM111DC on output. You can then swap the opamps to make a tighter sounding EQ. Gives you the best of both worlds.Any other suggestions for maximum sonic bliss?
Joe, thanks for the reply, that is exactly what I wanted to know!
Dingo for passive summing makeup gain.
An EE I'm not, although I've built several guitar amps, preamps and have a BA4 in my rack. I am thinking that I can use a diyrecordingequipment.com endless summer with a couple of Dingos with 99v's and JLM111DC's to make a line level in & out summing amp. Does that sound reasonable, and is there anything I should know before I order everything?
Bob
Bob
Re: Dingo for passive summing makeup gain.
Yes basically that is how we made the SUMO summing mixer. Uses the first balanced in opamp stage for summing all channels and then allows of master level control followed by second opamp and output transformer. Just change R3 & R5 from 20k to zero ohm links on dingo PCB and feed resistive balanced summing into dingo balanced input. I can do a simple drawing for you when you order if you remind me in the comments box of the order.rmiller335 wrote:An EE I'm not, although I've built several guitar amps, preamps and have a BA4 in my rack. I am thinking that I can use a diyrecordingequipment.com endless summer with a couple of Dingos with 99v's and JLM111DC's to make a line level in & out summing amp. Does that sound reasonable, and is there anything I should know before I order everything?
Bob
I have been at my Dingo over the holidays and came up with a few questions.
C 1+2 no strip on the side to mark "minus" - but legs different, the shorter
should be "minus", right?
C 5+7 / C 12+13 = are 16 volts, but 25 volts rating on the schematic.. (with my +/-24 v PSU) I guess that's okay because Joe knows what he does. No strip = shorter leg: minus
C6 and ZD1- not in the bag - located right near where the VCA goes - seems I just need those if I build something with the VCA.
ZD2+3: I don't need them, because I got +/- 24 volts
C9, R14: I don't need them, because I don't do an active EQ
R11: No VCA, no R11 needed
R12: another for the VCA
C8: without a value on the schematic - duh! Huh? I got no clue. Perhaps if stuff oscillates?
C1 and C2 in the kit are 10uF Non Polar so can go around.frans wrote:I have been at my Dingo over the holidays and came up with a few questions.
All 470uF are now 16v Non Polar types so can go in either way around. Voltage type could be as low as 10v as they are only blocking from a few millivolts with normal opamps to a couple of volts with JLM99v.C 5+7 / C 12+13 = are 16 volts, but 25 volts rating on the schematic.. (with my +/-24 v PSU) I guess that's okay because Joe knows what he does. No strip = shorter leg: minus
Correct. Only used on VCA compressor so not included.C6 and ZD1- not in the bag - located right near where the VCA goes - seems I just need those if I build something with the VCA.
Correct. Do not fit when providing +/-24v. Only use when running from 48v single rail like our 48v SMPS.ZD2+3: I don't need them, because I got +/- 24 volts
Correct. Only used on EQ so not included.C9, R14: I don't need them, because I don't do an active EQ
Correct. Only used on VCA compressor so not included.R11: No VCA, no R11 needed
Correct. Only used on VCA compressor so not included.R12: another for the VCA
Correct some opamps may oscillate if the circuit impedance driving there +in pin goes to high. If so a C8 of 47pF to 100pF will usually stop the oscillation.C8: without a value on the schematic - duh! Huh? I got no clue. Perhaps if stuff oscillates?
Joe, you make me feel smart!!!
frans wrote:Joe, you make me feel smart!!!
My slow build... (better slow than faulty) I hooked the Dingo (without the 99vs in their place) up to my +/-24v AC/DC and measured
at the opamp socket pins with my DMM. Plus and minus 24 volts are +24.4 /- 24.0, 0 volts is 0 volts, fine. (just made a note to revisit
the trimmer on the AC/DC to get the +24.4 closer to +24.0)
At the -input and output pin there's (debalancing side) +0.9 volts, same on the output/balancing side but with -1.4 volts on -input and output pins.
Is that okay?
I plan to build a MacOpto later this year and I've got an empty 19" that has been measuring equipment in it's former life, there's a nice PSU
in there with +/-15 volts and 5 volts. Which JLM opamps would fit that? I guess the debalancing side could take a OPA2604AP, but for the
output transformer I want something with more muscle, would the +/16v 99v be good or rather a JLM25HV or JLM25HVFET?
The 5 volts could supply the LEDs and maybe the relay on the Dingo?
Is that okay?
frans wrote:My slow build... (better slow than faulty) I hooked the Dingo (without the 99vs in their place) up to my +/-24v AC/DC and measured
Is that okay?
That all sounds fine.
On +/-15v with 1:2 output transformer you can use JLM99v LV, JLM25HV or FET, V8 etc.I plan to build a MacOpto later this year and I've got an empty 19" that has been measuring equipment in it's former life, there's a nice PSU
Another successful JLM build! I did the Pultec clone from the NRG forum with a Dingo and two 99v
http://www.nrgrecording.de/nrg/viewtopi ... sc&start=0
and even if there's a rat's nest of 36 wires from the board to the pots and switches (thank god for multi-pin connectors) I got everything to work at first attempt. Thanks to Joe, the patron saint of DIY and his very, very well thought-out multifunctional kits. I drooled over the pics of his Pultec and would prefer a JLM board where the switches and pots solder right on the board without wires - but I assume Joe got his reasons for not selling this board... and his finished Pultec is simply too much for my wallet but surely 101% worth it. Soooo... now on with the show: another two channels of 99v preamps are waiting in the basement...
