Micro Champ
Micro Champ
Hot off the bench. A champ guitar amp miniaturized from the original 6SJ7 and 6V6 to a EF86 and 6AQ5. Runs on external 12v SMPS and has internal DC to DC to make the 350v rail. Power on lamp is blue leds under the tubes. Sounds great :-)
astrovic
Post by astrovic »
Nice!!!
Did you whip that up while waiting for all the new boards to arrive?
chrisp
Post by chrisp »
But Joe, what happens when the drummer tries out the new stomp box?
astrovic
Post by astrovic »
LOL!! Took me a second, though... :D
poserp
Post by poserp »
Kit, kit, we want a kit... I have an old transistor amp that I'd like to overhaul (i.e., replace most of the electronics, keep the spring reverb and tremolo), and this would be the perfect thing for it. So here's my vote for making this into a kit at some point in time.
Moogus
Post by Moogus »
We built this for a local engineer (who just registered for the forum, I see) after I lent him my Champ which is just the standard 6SJ7+6V6+5Y3 type using New Sensor transformers - all old school and big and hot.
He loved the sound of it and asked us to build another. But of course we had to mess around with the design...
Its almost exactly the Champ circuit but with very modern PSU technology, and the equivilant miniature tubes to the 6SJ7 and 6V6. Its not quite as loud as my Champ, which is a good thing as it will be living in a studio thats built into a shipping container. So great sound at low volume is the order of the day.
Hes been using it for a few weeks now and reported it was running very hot, due to the complete lack of ventilation of the box. So we milled the top and bottom of the case with a pattern of 3mm holes, which seems to have fixed the heat problem. And it looks even better now.
Well put up an updated pic soon.
Im all for a PCB for this amp as it would be very simple and allow you to build one easily in a day. The lack of mains power inside the case makes it comparatively safe to build aswell.
Hopefully well post some sounds soon too.
M@
Permission to buzz the tower DENIED!!
Used the CNC Milling machine to add some top and bottom panel venting to get some air convection going as it was getting very hot.
Front panel has input jack, gain control, High boost switch, Pentode/Triode Switch and Power switch.
Back panel has 12vdc connector and speaker output jack.
Godders
Post by Godders »
I'd be all over a kit for one of these.
Nick
just.sounds
Micro Champ
Post by just.sounds »
This thing looks great! if it is going to be a kit i'm in for two!
:D
And this psu idea is also nice maybe you can make kits of that alone.
I think a lot of tube freaks would like such a psu for powering pre amps and make up gain amps. maybe even tube microphones. Keep up the good work!
toddd
Post by toddd »
don't make us beg joe...
Moogus
Post by Moogus »
Give us some idea of what people would want to pay for a full kit for an amp like this (ie drilled case included). Or would you just want parts and make your own case?
M@
just.sounds
BOM
As a dutch guy I have to be a cheap bastard so i would say
As cheap as possible :)
But i would like a kit with housing but without all the parts that are in the signal path.
I think you can make them cheaper than at
http://www.tubeampdoctor.com
Bear
Post by Bear »
What sort of chasis size are you using?
Bear
Diecast box measuring 119mm (4.7") x 93mm (3.7") x 55mm (2.2")
Bear
Post by Bear »
Wow, that is tiny. A Hammond 1590D box would be even roomier. I might collapse one of those trying a similar project put with a power transformer.
Bear
