Hi all,
First time poster. Wondering what the jumpers in the DI socket on the PCB are actually for? I dont have a DI running on either of my channels and Im getting no signal out of them. Im thinking these jumpers missing would be the cause of the problem. Being so small I lost them, and I can find any in the shops anywhere, but if they are essential (as you would think, they wouldnt be there for nothing) , Ill find them somewhere. Thanks.
Yes the 2 jumpers in the DI header are to link the audio to the input when no DI is fitted. Fit the 2 jumpers where shown and it will complete the input path. You Can just solder the 2 pairs of pins together under the PCB if you do not have the jumpers.timos wrote:Hi all,
The PDF http://www.jlmaudio.com/Baby%20Animal%2 ... PA2604.pdf is password protected.
Please read the first thread on the forum at the link belowsonicwarrior wrote:The PDF http://www.jlmaudio.com/Baby%20Animal%2 ... PA2604.pdf is password protected.
PDF Problems on JLM Site Please Read
Well just ordered a BA4, look forward to it. Going to be building it with a few Jensen in/out transformers & some 990c's.
I have a few areas I'm unsure about.
1. What would the optimum Jumper, RL & CL values be for a Jensen JT-11K8-APC 150:1.8k input with a JH990c?
2. What would the optimum Jumper, RL & CL values be for a Jensen JT-MB-CPCA 150:150 input with a JH990c?
3. What would the optimum 68R RGain value for use with the 990c
4. Would using a JT-OLI-3 be beneficial? Where would they live? Would they eliminate anything else otherwise needed in the path?
"Any experiment of interest in life will be carried out at your own expense." [url]http://rhythminmind.net[/url] - [url]http://signaltonoize.com[/url] - [url]http://popsound.com[/url]
OK I see the order in the systemEric Beam wrote:Well just ordered a BA4, look forward to it. Going to be building it with a few Jensen in/out transformers & some 990c's.
okI have a few areas I'm unsure about.
From the Jensen Datasheet Rload = 15k. Cload , CZobel or RZobel not needed or fitted.1. What would the optimum Jumper, RL & CL values be for a Jensen JT-11K8-APC 150:1.8k input with a JH990c?
From the Jensen Datasheet Rload = 3k. Cload , CZobel or RZobel not needed or fitted.
Since the 990c is a high gain opamp you should be able to get down to 10R for RGain giving heaps of extra gain.3. What would the optimum 68R RGain value for use with the 990c
No not needed the the BA has all you need on there for isolating the output already.4. Would using a JT-OLI-3 be beneficial? Where would they live? Would they eliminate anything else otherwise needed in the path?
Thanks for the info.
If I wanted to use the impedance knob, How do you come up with the variable Z values?
Out of curiosity, I already have the JT-OLI-3 output isolators. Would they eliminate the need for the 51R & 470uF if I used them before output pins 2 & 3? Or maybe just the 51R? Not sure what the DC situation is coming out of the 990.
Try changing 15k to be 50k log pot in series with 1k8 resistor. Change 3k to be 10k log pot in series 150R. Centre Z position will be rough 1k input impedance for both.Eric Beam wrote:Thanks for the info.
The 51R can be replace the JT-OLI-3 but you canNOT remove the 470uF cap or you will fry the output transformer with +24vdc. Connect the output transformer between +out and 0v on the primary. If the pre is sounding to harsh it is usually the ringing in the output transformer caused by no output resistance. If to harsh go back to a series resistor of 10R to 51R instead of the JT-OL1-3.Out of curiosity, I already have the JT-OLI-3 output isolators. Would they eliminate the need for the 51R & 470uF if I used them before output pins 2 & 3? Or maybe just the 51R? Not sure what the DC situation is coming out of the 990.
Thanks again.
I'll experiment with the isolator & check ringing with a scope.
A while back I build a BAD (with a pair of JH99C and Lundahl 1538) that has worked great until recently.
When I power it up it goes into a cycle of "power LED lights up and slowly ramps down" (sawtooth like)at a frequency of about once a second. If I pull the +48v feed off the BA and re-insert it, then it behaves correctly.
N.B. this BAD is in a BA4 case with three BAs powered by a JLM 48v/380ma supply and they are all working properly if the BAD is left un-powered. Any thoughts...?
Sylvain
Sylvain
Switchmode is in 120% overload hiccup protection mode which will cycle it on and off like you explain. Does the power supply run the BAD by itself with no other BA kits ok? If not there is a fault on the BAD kit?Sylvain wrote:Hi Joe,
Sylvain
Aha!Joe Malone wrote:Switchmode is in 120% overload hiccup protection mode which will cycle it on and off like you explain. Does the power supply run the BAD by itself with no other BA kits ok? If not there is a fault on the BAD kit?Sylvain wrote:Hi Joe,
Sylvain
It looks like it's the power supply.
Your mention of "120% overload" put a bug in my ear about current draw.
Any three BA and/or BAD combination will work together. But not all four.
This is a "GS25A48-P1J" supply.( s/n R090507455)...(I think this supply gave me a similar problem about a year ago with a "BA2 everything" kit.)
I tried another supply: an "ES18A48-480" and it works fine.
Ironically the supply that works is rated at a lower current(0.375A) and the supply that is choking is rated at 0.5A.
FYI, the rack contains 1 BA w/99V, 1 BA /JLM Hybrid, 1 BAN w/2x 2604 and 1 BAD w/2xJH990c. I did'nt do the math, but I assume that the GS25A48-P1J should be able to handle this combined load...
I guess I'll need a new supply.
Sylvain
There is nothing wrong with the supply except that it is MEPS Green low standby version. Please read the info below from the first post in this Build Thread.
My advice would be to use the 48v 380mA NON MEPS supply with this BA4 and the 48v 520mA MEPS one with the BA2. Or look into the below options.
Notes & Errata
BA MEPS SMPS Soft start mod
BAD MEPS SMPS Soft start mod
BAN MEPS SMPS Soft start mod
Notes & Errata
OK
That explains it all.
I had'nt seen the "Notes & Errata" about this since I build these BAs(&BAD) before this issue showed-up on the forum. They had all behaved correctly until I inadvertantly swithched the supplies...
I'll perform the mod to all my BAs. I think the "soft start" option is probably healthyer for the electronics in the long run...
Thanks for pointing this out Joe.
Sylvain
Sylvain
Just swap the power supplies back to the way it used to be and no need to do any mods if they work that way. The caps are fine either way.
