HAL
HAL
CPU PCB (1.38" x 2") + STEREO VOLUME CONTROL PCB (1.38"x 2") + DISPLAY PCB (1.38" x 2.8")
CPU PCB allow you to use a rotary encoder or linear pot to control volume from -96 to 31.5dB in 0.5 dB steps as well as 16 switches wired in a 8 wire matrix. The CPU serial out can control volume controls up to eight channel 7.1 systems. Also 16 relays and 16 lamps as well as a four digit display in red or blue.
The 16 momentary switches come set as 16 seperate push on/off switches but you can wire any lamp output to any illuminated switch or relay and the rest can be rearranged in the CPU setup menus. Also switches can be set to 4 interlock banks so you can interlock for example inputs so pushing one switch will release any others in that interlock group.
The volume PCB uses a PGA2310 or PGA2320 for the stereo volume control and plug into 2 of our dINgO IN/OUT pcbs to give balanced in and output.
All of the above is working with just fiine tuning to the setup menu etc and a few new features and then we will release some kits to beta testing.
Presenting working on Relay/Lamp PCB and Relay Volume Control PCB.
Re: HAL
Has this kit been and gone or never quite made it? Cant seem to find it anywhere other than here....
Re: HAL
We use HAL to make lots of custom controllers etc but have never released it as a normal kit as the builder needs to be advanced to usually work out exactly what they want and to make any custom relay switching PCBs etc. If there was a standard configuration people would like to see I would look at making some standard relay I/O PCB's to make it easy to use.wizardofoz wrote:Has this kit been and gone or never quite made it? Cant seem to find it anywhere other than here....
Re: HAL
Reviving a thread that has not been visited for a while.
Given the continual change of many people from big studios to their own set-ups, I think that your last post suggesting a standard Hal Setup which could appeal to many users is definitely something I would be interested in, I'm sure others would be too.
Having thought about it quite a bit, It seems like most users would want a group of 4 interlocking switches for input select, 4 interlocking switches for output (speaker select) and possibly 2 banks of 4 switches functioning as independent on off selectors, (as useful in mastering style consoles, but equally useful to trigger mono/dim/L-R reverse/L speaker ø functions.
Is this available in any way as a kit or could it be spec'd as a fully designed system? I'm looking for something for my new control room.
cheers
Richard
cheers
Richard
