can anyone help.....
I purchased a Mac and a Dingo kit with an external 48VDc power supply (think its switch mode, looks like a laptop power supply). The dingo power input is +24 0 -24. I'm really unsure if I can just connect the 48V accross the -24 +24, or do I need a Power rail splitter, the rest of the build is complete, but i don't want to let the smoke out...
48v SMPS and Dingo connection
Re: 48v SMPS and Dingo connection
The MAC and dingo can be run with a 48v SMPS as long as you use a plastic isolated DC connector and add 2 x 24v zeners across one of the opamps power pins on the dingo. So there is a 24v zener between +V (zener stripe) & 0v and 0v (zener stripe) & -V. Wire the 48v SMPS +48v to +V and 48v SMPS 0v to -V on the dingo and you can take the dingo 0v that is not used to the metal case. See photo below.
I have a problem either with my smps or motherboard in my computer! pls help me? the monitor of my computer automatically turns off after sometime , but the led at the dvd drive remains on,also the fan on the motherboard stops, while one in the smps is on. pls help me n let me know what is the cure for this.
______________________
keyword research ~ keyword tool ~ keyword tracking ~ affiliate elite
What is the 48v SMPS powering that is connected to the computer? And how and what else is it connected to?crysthane wrote:I have a problem either with my smps or motherboard in my computer! pls help me? the monitor of my computer automatically turns off after sometime , but the led at the dvd drive remains on,also the fan on the motherboard stops, while one in the smps is on. pls help me n let me know what is the cure for this.
