hey Joe and JLM:
I'm on the hunt for some DI jacks similar to the ones in your DI. I haven't had any success finding these anywhere in the states.
Would you mind telling who makes those jacks and where you get them?
Thanks !
JLM DI Input Jack (with switch) Source
You will be much better off fitting the DI with a jack like Chrisp suggested where you have a DPDT on the switch but not PCB board mounted. The jack with the DI is not very deep and can be easily stripped when placed on a panel. I have done it before. I'd suggest an external jack that you wire up to the PCB board and affix the PCB board in a different manner.
CC
CC
agreed... i've always used a separate jack myself. i really like the quality of the cliff brand ones. you can get them insulated with the chrome nut and they look quite spiffy.
i think i just drilled a 3mm hole in the pcb and mounted it to the case. wired the jack with a little bit of shielded cable...
if you really want the EXACT jack socket joe uses i guess you'll have to wait to hear from him. i don't think i've seen it in any catalogs i have. i've seen similar ones in various bits of gear - i guess it's a common part in asia but not here?
good luck!
good luck!
