GAIN Mic Pre / Makeup Amp Kit
Re: GAIN Mic Pre / Makeup Amp Kit
I little messy on this test unit from larger parts I had in stock, but I checked every connection, I must one missing something.
Thanks for the help, I get one right, I can do the other 5...
RLOAD is 600Ω, what the EQ wants to see.
I would ohm test the tracks back to the 470uF to one end of RGain and the other end of RGain to GAIN terminal. Encase a pad has been broken off a track.
As the soldering is a bit messy to see I would clean the pcb with alcohol and a toothbrush as well.
Ok! So I bought multiple GAIN PCB, so I did up another from scratch and works correctly.
Thanks for your help with my 1st DIY.
***One question regarding connecting power to (2) units.
Series or parallel from your: 48v 25w 520mA Switch Mode Power Supply. ??
You can only run multiple gains on 48v smps in parallelJOETONE wrote: ↑Tue Apr 04, 2023 3:22 amOk! So I bought multiple GAIN PCB, so I did up another from scratch and works correctly.
I'm planning on feeding (2) GAIN kits from (2) Jensen JT-16-A for MIC pre input.
https://www.jensen-transformers.com/wp- ... -16-a1.pdf
Can you tell me what to fit for CZ,RZ,RLoad,CLoad?
Rload is 6k19 = 6.2k
Cload is not needed (leave blank)
RZobel is 4k53 =4.53k
CZobel is 620pF
From the datasheet you linked toJOETONE wrote: ↑Mon May 08, 2023 10:20 amHi Joe,
CZobel is 620pF
Joe sorry to bother you again.
Jensen here in the US has no supply, backordered for long time on the JT-16-A.
Could you let me know same info, RLoad, RZobel, CZobel for this model recommended substitute.
https://www.jensen-transformers.com/wp- ... 15K-e1.pdf
JT-115k only needs Rload of 150k. No RZobel or CZobel or Cload are needed so are left blank.JOETONE wrote: ↑Wed May 10, 2023 5:10 amJoe sorry to bother you again.
THANK YOU - you have been incredibly helpful. Much appreciated.
Thanks for your help!
Finished up this rack of 2 Fairchild EQ's with your gain PCB's for make up gain, sound great., kinda like a LANG.
Cool neat build. Great to hear you got it all working
