LA500A opto comp MAY 2021 BUILD THREAD 500/51X
Re: LA500A opto comp MAY 2021 BUILD THREAD 500/51X
Dolbah wrote:
Sat Nov 06, 2021 8:30 am
I just built two of these units, and all seems fine. But, I am not able to get any reaction on the VU needle when turning the "Meter 0 VU" trim pot.
This applies to both units, I also tried to switch to GR and tested the GR pot, but still no reaction. I also tried putting the jumper over to "match" put I get nothing at all.
Threshold and all other functions react as expected and sound is flowing through.
  • I am sending 1000hz tone from my DAW, into the unit(s) and I have adjusted the input dB so that the LA output is showing exactly 1,23VAC, the needle is beyond 4dB on the VU.
  • All knobs counter clockwise
  • Ratio 3:1
  • Meter: VU
  • HPF: Flat
Any tips on this one?
First are you using the blue 0VU trimpot on SC PCB to set the +4dBu = 0VU? Some people mistakenly use the -20 mechanical set screw on the front of the meter which is only for setting the -20 point when the comp is off. If this set screw is moved it needs to be reset correctly before doing the calibration to the comp.
With 1.23vac on the LA500A output measured between pin 2 & pin 3 of the output XLR on first power up with no trimpots touched the VU meter will always read about -2VU and need to be turned up a couple of dB. If your VU meter reads higher usually you are reading the 1.23vac between pin 2 & pin 1 of the output XLR so really have 2.46vac.
In GR the meter will be off scale and need to be turned down several turns with Zero trimpot.
Dolbah
Post by Dolbah »
Sat Nov 06, 2021 8:52 am
  • Ratio 3:1
  • Meter: VU
  • HPF: Flat
Yes, I'm on the Blue trimpots ;)
But, yes! I was using wrong pins, looks good now. Thanks!
