AUX8 Build thread
AUX8 Build thread
Notes and Errata Ver 1 PCB.
fragletrollet
Re: AUX8 Build thread
Post by fragletrollet »
fragletrollet wrote:
Tue Nov 24, 2020 2:16 am
Thanks for posting Magnus :D 8)
