I'm making a front panel for a 4-channel pre using Go-Betweens. I saw the drill description for the switch spacing on the kit page, but I don't see where it says what the hole size should be for the phantom LED bezel. I'm guessing around 4mm, but I want to be sure. Thanks!
Go Between and Go Between Plus kit BUILD THREAD
Re: Go Between and Go Between Plus kit BUILD THREAD
Hi see attached spec for the bezel. It has a front 5.9mm flange and can have a 4.2mm hole with rear 5.2mm countersink or 4.8 to 5.2mm hole. But best to have a bezel with you to see the best way to go for you.PeterBregman wrote: ↑Mon Apr 20, 2020 7:55 amHi Joe,
We just mount the 3mm led in 3mm hole in our products now.
Hello! I've used the Go Between kits on several projects now but I just tried adding a Variable Pad kit to the front end of a preamp for the first time and, when phantom power is applied, the variable pad pot is extremely scratchy. With phantom power off, all is well with the world. Is this a known limitation or is there something I should try to debug?
My only guess is that the phantom is introducing DC on the pot and the carbon pot is not working well under those conditions but I have a pretty solid track record of being wrong about these things.
Dan
Dan
HI Dandanmohr wrote: ↑Wed Jul 29, 2020 4:23 amHello! I've used the Go Between kits on several projects now but I just tried adding a Variable Pad kit to the front end of a preamp for the first time and, when phantom power is applied, the variable pad pot is extremely scratchy. With phantom power off, all is well with the world. Is this a known limitation or is there something I should try to debug?
Dan
Make sure you have no DC path to 0v, usually by a centre tap on an input transformer going to 0v ground. The whole input circuit should be floating or the phantom power will not work properly anyway.
Do you have a circuit for the input of the pre amp you are running this go between and Variable pad into? And a couple of photos of the wiring etc.
