This kit provides a quick and easy way to add 48v phantom power, 20dB PAD, Phase reverse & Input transformer to help rack API & Quad8 etc amp cards or add these extra features to mic pres without them. Also has a IDC connected for adding the JLM Active DI kit in seconds. Go between Plus PCB can take all the input transformers that Baby Animal and Dual 99v PCB's can take and has input & output ratio jumpers as well as places for Rload, Cload, Rzobel, Czobel parts on the PCB. Transformer secondary is available on the output terminal as a floating balanced signal which can be strapped to unbalanced as well.
Build GO Between PCB exactly as overlay shows.
Build from the lowest height component to the highest. eg Resistors, Terminals, IDC10 header, 10uF cap, Switches.
When fitting the switches just solder one leg first so the switches can be lined up in a neat row before soldering all switch legs.
LED solders to the top 2 switch legs of the 48v switch with the Anode long leg closest to the edge of the PCB.
Resistor in red oval is the LED resistor and can have its value changed if using a different LED.
If not using DI kit fit 2 jumpers in header as PCB overlay shows.
GO Between PCB Schematic here
GO Between PCB Parts list here
Build Go Between Plus exactly as overlay shows.
Build from the lowest height component to the highest. eg Resistors, Terminals, IDC10 header, 10uF cap, Switches, Transformer.
The 6k8 Resistor closest to the edge of the PCB is the LED resistor and can have its value changed if using a different LED.
GO Between Plus PCB Schematic here
GO Between Plus PCB parts list here
Now Available on the website here
